[GRASS-user] v.to.db area calculations
Moritz Lennert mlennert at club.worldonline.be
Wed May 24 02:36:12 PDT 2017
On 24/05/17 11:06, James Duffy wrote:
> Hello,
> Thank you for your investigations.
> Is there anything else I can do about this? I trust my QGIS measurement
> because I know the size of the object I have drawn around.
But as you say below:
>>         OTF is turned off in QGIS, I am working in EPSG 4326.
>>         The 0.127m2 comes from using the Measure tool (OTF off) in QGIS.
>>         And it
>>         is set to display m2.
As I showed with my test, the value of 0.127m2 is probably wrong. In the
case of the 10000m2 rectangle, I get an error of over 2000m2 with OTF
off on an EPSG 4326 ! Only with OTF on, I get a result closer to the
true size.
Would you be willing to share your test polygon ?
Moritz
> However I
> would really like to use GRASS to automate my workflow...
> Thanks
> James
> On 19 May 2017 at 13:41, Moritz Lennert <mlennert at club.worldonline.be
> <mailto:mlennert at club.worldonline.be>> wrote:
>     On 19/05/17 11:25, James Duffy wrote:
>         Just to clear a few things up.
>         The shapefile contains only a single polygon (I created it as a
>         simple
>         test to work out this discrepancy).
>         And it
>         Using the $area calculator in the field calculator in QGIS does
>         indeed
>         show something that is more likely degrees squared.
>     Below some results from quick tests.
>     Summary: personally I would trust GRASS GIS a bit more, but I'm
>     biaised...
>     Test 1:
>     GRASS trunk in NC demo location (EPSG 3358)
>     g.region n=200100 s=200000 w=500000 e=500100 -ap
>     v.in.region out=nc_testpolygon
>     v.to.db -p nc_testpolygon op=area --q
>     1|10000
>     GRASS trunk in EPSG 4326 location
>     v.proj location=nc_spm_08 mapset=user1 input=nc_testpolygon
>     1|10002.503642603
>     v.out.ogr nc_testpolygon out=nc_testpolygon.shp (i.e. shapefile is
>     in degress, EPSG 4326)
>     QGIS (using the exported shapefile)
>     No OTF
>     measuring tool: 12.324,737 m²
>     $area in calculator: 12320.2346026
>     OTF to EPSG 4326, with datum WGS84
>     measuring tool: 10.072,355 m²
>     $area in calculator: 10046.3679510
>     Test 2:
>     GRASS trunk, in ESPG 4326 location
>     g.region n=74 s=73 w=0 e=1 res=1 -p
>     v.in.region region_1degree_73_74N
>     v.to.db -p region_1degree_73_74N op=area --q
>     1|3539348689.40454
>     v.out.ogr region_1degree_73_74N out=region_1degree_73_74N.shp
>     GRASS trunk in EPSG 3575 location
>     v.proj location=LL_WGS84 mapset=mlennert input=region_1degree_73_74N
>     1|3539337483.97153
>     no OTF projection
>     measuring tool 1,002 m² (sic)
>     export geometry column: 1
>     $area in calculator 12392029030 <tel:12392029030>.5000000
>     with OTF projection, datum for measurements WGS84
>     measuring tool 3.503.322.774,337 m²
>     $area in calculator: 3499702798.3400998
>     reproject to EPSG 3575
>     with OTF, datum WGS84
>     export geometry column 3539169026.18628
>     export geoemtry column (column named otf) 3499702798.00000
>     $area in calculator: 3499702798.6579294
> *James Duffy*
> PhD Researcher
> Environment and Sustainability Institute
> Penryn Campus
> University of Exeter
> Penryn
> Cornwall
> TR10 9FE
