[GRASS-user] v.class.mlR error
Moritz Lennert
mlennert at club.worldonline.be
Thu May 25 03:43:39 PDT 2017
Le Thu, 25 May 2017 10:54:18 +0100,
James Duffy <james.philip.duffy at gmail.com> a écrit :
> Hi Moritz,
> Your suggested edits to v.class.mlR.py worked (except you had one too
> many brackets on the end of each line, so I removed those). Once I
> updated and saved that script file, the error disappeared.
> I have just reinstalled the module using g.extension and tried running
> v.class.mlR and I again have the original error regarding escaped
> slashes.
I had just copied and pasted from my message, so the problem you found
with one too many brackets was also in the file. I just fixed that.
Sorry, don't have the opportunity to test myself right now, so doing
this a bit blindly.
Moritz
