[GRASS-user] v.class.mlR error
James Duffy
james.philip.duffy at gmail.com
Thu May 25 04:18:52 PDT 2017
I've just tried using a csv as input instead of a vector file and I get the
same error, now relating to the path of the csv. Could I suggest also
putting in a check / replace line for csv paths if they are entered from a
windows machine (especially using the GUI).
Thank you.
James
On 25 May 2017 at 11:43, Moritz Lennert <mlennert at club.worldonline.be>
wrote:
> Le Thu, 25 May 2017 10:54:18 +0100,
> James Duffy <james.philip.duffy at gmail.com> a écrit :
> > Hi Moritz,
> > Your suggested edits to v.class.mlR.py worked (except you had one too
> > many brackets on the end of each line, so I removed those). Once I
> > updated and saved that script file, the error disappeared.
> > I have just reinstalled the module using g.extension and tried running
> > v.class.mlR and I again have the original error regarding escaped
> > slashes.
> I had just copied and pasted from my message, so the problem you found
> with one too many brackets was also in the file. I just fixed that.
> Sorry, don't have the opportunity to test myself right now, so doing
> this a bit blindly.
> Moritz
*James Duffy*
PhD Researcher
Environment and Sustainability Institute
Penryn Campus
University of Exeter
Penryn
Cornwall
TR10 9FE
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170525/b38e55ca/attachment.html>
