[GRASS-user] FileGDB has 3 layers, only first imported
Markus Metz markus.metz.giswork at gmail.com
Wed Nov 1 11:28:28 PDT 2017
On Wed, Nov 1, 2017 at 6:22 PM, Rich Shepard <rshepard at appl-ecosys.com>
wrote:
>   The hydrography source is from the National Hydrographic Database and
> contains three layers: Major_Streams, Major_Areas, Major_WaterBodies.
Within
> the v.in.ogr GUI dialog I checked all three layers for import. When grass
> finished processing I checked g.list and found only the first layer
present.
> I assume the layer output names default to the layer input names.
>   What might I have missed?
OGR layers correspond to GRASS layers. If you use v.in.ogr without
specifying a layer, all layers present in the OGR datasource are imported
into one single GRASS vector, but as separate layers. You can check with
v.category op=report.
Markus M
> Rich
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20171101/d6e087d6/attachment-0001.html>
