[GRASS-user] FileGDB has 3 layers, only first imported
Rich Shepard
rshepard at appl-ecosys.com
Wed Nov 1 11:54:02 PDT 2017
On Wed, 1 Nov 2017, Markus Metz wrote:
> OGR layers correspond to GRASS layers. If you use v.in.ogr without
> specifying a layer, all layers present in the OGR datasource are imported
> into one single GRASS vector, but as separate layers. You can check with
> v.category op=report.
Markus,
The manual page also states that if all layers are provided they will be
imported into a single grass vector as separate layers.
If that is what happened, how do I load individual layers? When I use the
GUI to display a vector map I see only the first one. I've not before worked
with multiple laysers on a single vector map.
Rich
