[GRASS-user] FileGDB has 3 layers, only first imported
    Helmut Kudrnovsky
    hellik at web.de
    Wed Nov  1 11:57:32 PDT 2017
> If that is what happened, how do I load individual layers? When I use the
>GUI to display a vector map I see only the first one.
according to the manual:
https://grass.osgeo.org/grass73/manuals/d.vect.html
d.vect [-cirs] map=name [layer=string] [...]
layer=string
    Layer number or name ('-1' for all layers)
    A single vector map can be connected to multiple database tables. This
number determines which table to use. When used with direct OGR access this
is the layer name.
    Default: 1
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
