[GRASS-user] r.stream.extract error
Markus Metz
markus.metz.giswork at gmail.com
Wed Nov 1 14:52:58 PDT 2017
On Wed, Nov 1, 2017 at 10:41 PM, Giuseppe Amatulli <
giuseppe.amatulli at gmail.com> wrote:
> Thanks again!!
> I'm working with a area-flowaccumulation so the 0.5 threshold means 0.5
km2, which is 90m * 90m * 60 cell.
I forgot to mention that the unit of the threshold option is cells, not
squared map units. That means you need to change the threshold value.
Markus M
> My intention is prune back the stream later on with a machine learning
procedure. I will be carefully look not to overpass the 2,147,483,647
detected stream segments.
> To reduce as much as possible I/O I save the *.tif file in the /dev/shm
of each node, read then with r.external and build up the location on the
flight in each /tmp. So, it quite fast. I will try to increase a bit the
RAM.
> Will post later how is going.
> Best
> Giuseppe
> On 1 November 2017 at 17:12, Markus Metz <markus.metz.giswork at gmail.com>
wrote:
>> On Wed, Nov 1, 2017 at 7:15 PM, Giuseppe Amatulli <
>> > Thanks Markus!!
>> > I will test and I will let you know how it works.
>> Your feedback is very helpful!
>> > I have few more questions
>> > 1) now how much is the upper limit matrix cell number that
r.stream.extract can handle?
>> About 1.15e+18 cells.
>> Another limitation is the number of detected stream segments. This must
not be larger than 2,147,483,647 streams, therefore you need to figure out
a reasonable threshold with a smaller test region. A threshold of 0.5 is
definitively too small, no matter how large or small the input is.
Threshold should typically be larger than 1000, but is somewhat dependent
on the resolution of the input. As a rule of thumb, with a coarser
resolution, a smaller threshold might be suitable, with a higher
resolution, the threshold should be larger. Testing different threshold
values in a small subset of the full region can safe a lot of time.
>> > 2) is the r.stream.basins add-on subjects to the same limitation? In
case would be possible to update also for r.stream.basins?
>> The limitation in r.watershed and r.stream.extract comes from the search
for drainage directions and flow accumulation. The other r.stream.* modules
should support large input data, as long as the number of stream segments
does not exceed 2,147,483,647.
>> > 3) is r.stream.extract support the use of multi-threaded through
openMP? Would be difficult implement?
>> In your case, only less than 13% of temporary data are kept in memory.
Parallelization with openMP or similar will not help here, your CPU will
run only at less than 20% with one thread anyway. The limit is disk I/O.
You can make it faster by using more memory and/or using a faster disk
storage device.
>> Markus M
>> > Best
>> > Giuseppe
>> > On 31 October 2017 at 15:54, Markus Metz <markus.metz.giswork at gmail.com>
wrote:
>> >> On Mon, Oct 30, 2017 at 1:42 PM, Giuseppe Amatulli <
>> >> > Hi,
>> >> > I'm using the r.stream.extract grass command
>> >> > r.stream.extract elevation=elv accumulation=upa threshold=0.5
depression=dep direction=dir stream_raster=stream memory=35000 --o
--verbose
>> >> > where the elv is raster of 142690 * 80490 = 11,485,118,100 cell
>> >> > and I get this error
>> >> > 12.97% of data are kept in memory
>> >> > Will need up to 293.52 GB (300563 MB) of disk space
>> >> > Creating temporary files...
>> >> > Loading input raster maps...
0..3..6..9..12..15..18..21..24..27..30..33..36..39..42..45..48..51..54..57..60..63..66..69..72..75..78..81..84..87..90..93..96..99..100
>> >> > ERROR: Unable to load input raster map(s)
>> >> This error is caused by integer overflow because not all variables
necessary to support such large maps were 64 bit integer.
>> >> Fixed in trunk and relbr72 with r71620,1, and tested with a DEM with
172800 * 67200 = 11,612,160,000 cells: r.stream.extract finished
successfully in 18 hours (not a HPC, a standard desktop maschine with 32 GB
of RAM and a 750 GB SSD).
>> >> > According to the help manual the memory=35000 should be set in
according to the overall memory available. I set the HPC upper memory limit
to 40G.
>> >> > I try several combination of these parameters but i still get the
same error.
>> >> > If the r.stream.extract is based on r.watershed than the
segmentation library should be able to handle a huge raster.
>> >> r.stream.extract is based on a version of r.watershed that did not
support yet such huge raster maps, therefore support for such huge raster
maps needed to be added to r.stream.extract separately.
>> >> > Anyone know how to over pass this limitation/error ?
>> >> Please use the latest GRASS 7.2 or GRASS 7.3 version from svn.
>> >> Markus M
>> >> > Thank you
>> >> > Best
>> >> > Giuseppe Amatulli, Ph.D.
>> >> > Research scientist at
>> >> > Yale School of Forestry & Environmental Studies
>> >> > Yale Center for Research Computing
>> >> > Center for Science and Social Science Information
>> >> > New Haven, 06511
>> >> > Teaching: http://spatial-ecology.org
>> >> > Work: https://environment.yale.edu/profile/giuseppe-amatulli/
>> >> > _______________________________________________
>> >> > grass-user mailing list
>> >> > grass-user at lists.osgeo.org
>> >> > https://lists.osgeo.org/mailman/listinfo/grass-user
>> > New Haven, 06511
> New Haven, 06511
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20171101/b9fcf89c/attachment-0001.html>
