[GRASS-user] r.stream.extract error
Giuseppe Amatulli giuseppe.amatulli at gmail.com
Wed Nov 8 06:47:01 PST 2017
Hi Markus,
I have compile the GRASS7.2.3svn
r.stream.extract elevation=elv  accumulation=upa threshold=0.5
 depression=dep     direction=dir  stream_raster=stream memory=45000 --o
--verbose
with a small area
expr 600 \*  310  = 186 000 and everything works fine.
If I enlarge the area
expr  72870 \* 80040  = 5 832 514 800
I get the following warning
16.67% of data are kept in memory
Will need up to 293.52 GB (300563 MB) of disk space
Creating temporary files...
Loading input raster maps...
0..3..6..9..12..15..18..21..24..27..30..33..36..39..42..45..
48..51..54..57..60..63..66..69..72..75..78..81..84..87..90..93..96..99..100
Initializing A* search...
0..WARNING: Segment pagein: read EOF
WARNING: segment lib: put: pagein failed
WARNING: Unable to write segment file
and than the stream is not created.
Is something due with  compile of the GRASS7.2.3svn ?
or something else?
Concerning the threshold: I'm using area-flow-accumulation expressed in
km2. So this means that each pixel have a value of the upper stream
sum-area in km2. So if I fix the threshold to 0.5 means that my stream will
start when all the cells below have value > 0.5. I have check and look
correct to me, in fact my smallest upper stream basin have 7 cell 90*90  (
~ 1/2 km2).
Thank you
Giuseppe
On 1 November 2017 at 17:52, Markus Metz <markus.metz.giswork at gmail.com>
wrote:
> On Wed, Nov 1, 2017 at 10:41 PM, Giuseppe Amatulli <
> giuseppe.amatulli at gmail.com> wrote:
> > Thanks again!!
> > I'm working with a area-flowaccumulation so the 0.5 threshold means 0.5
> km2, which is 90m * 90m * 60 cell.
> I forgot to mention that the unit of the threshold option is cells, not
> squared map units. That means you need to change the threshold value.
> Markus M
> > My intention is prune back the stream later on with a machine learning
> procedure. I will be carefully look not to overpass the 2,147,483,647
> detected stream segments.
> > To reduce as much as possible  I/O I save the *.tif file in the /dev/shm
> of each node, read then with r.external and build up the location on the
> flight in each /tmp. So, it quite fast. I will try to increase a bit the
> RAM.
> > Will post later how is going.
> > Best
> > Giuseppe
> > On 1 November 2017 at 17:12, Markus Metz <markus.metz.giswork at gmail.com>
> wrote:
> >> On Wed, Nov 1, 2017 at 7:15 PM, Giuseppe Amatulli <
> >> > Thanks Markus!!
> >> > I will test and I will let you know how it works.
> >> Your feedback is very helpful!
> >> > I have few  more questions
> >> > 1) now how much is the upper limit matrix cell number that
> r.stream.extract can handle?
> >> About 1.15e+18 cells.
> >> Another limitation is the number of detected stream segments. This must
> not be larger than 2,147,483,647 streams, therefore you need to figure out
> a reasonable threshold with a smaller test region. A threshold of 0.5 is
> definitively too small, no matter how large or small the input is.
> Threshold should typically be larger than 1000, but is somewhat dependent
> on the resolution of the input. As a rule of thumb, with a coarser
> resolution, a smaller threshold might be suitable, with a higher
> resolution, the threshold should be larger. Testing different threshold
> values in a small subset of the full region can safe a lot of time.
> >> > 2) is the r.stream.basins add-on subjects to the same limitation? In
> case would be possible to update also for  r.stream.basins?
> >> The limitation in r.watershed and r.stream.extract comes from the
> search for drainage directions and flow accumulation. The other r.stream.*
> modules should support large input data, as long as the number of stream
> segments does not exceed 2,147,483,647.
> >> > 3) is r.stream.extract support the use of multi-threaded through
> openMP? Would be difficult implement?
> >> In your case, only less than 13% of temporary data are kept in memory.
> Parallelization with openMP or similar will not help here, your CPU will
> run only at less than 20% with one thread anyway. The limit is disk I/O.
> You can make it faster by using more memory and/or using a faster disk
> storage device.
> >> Markus M
> >> > Best
> >> > Giuseppe
> >> > On 31 October 2017 at 15:54, Markus Metz <
> markus.metz.giswork at gmail.com> wrote:
> >> >> On Mon, Oct 30, 2017 at 1:42 PM, Giuseppe Amatulli <
> >> >> > Hi,
> >> >> > I'm using the r.stream.extract grass command
>  depression=dep     direction=dir  stream_raster=stream memory=35000 --o
> --verbose
> >> >> > where the elv is raster of 142690 *  80490 = 11,485,118,100 cell
> >> >> > and I get this error
> >> >> > 12.97% of data are kept in memory
> 93..96..99..100
> >> >> > ERROR: Unable to load input raster map(s)
> >> >> This error is caused by integer overflow because not all variables
> necessary to support such large maps were 64 bit integer.
> >> >> Fixed in trunk and relbr72 with r71620,1, and tested with a DEM with
> 172800 * 67200 = 11,612,160,000 cells: r.stream.extract finished
> successfully in 18 hours (not a HPC, a standard desktop maschine with 32 GB
> of RAM and a 750 GB SSD).
> >> >> > According to the help manual the memory=35000 should be set in
> according to the overall memory available. I set the HPC upper memory limit
> to 40G.
> >> >> > I try several combination of these parameters  but i still get the
> same error.
> >> >> > If the r.stream.extract is based on r.watershed than the
> segmentation  library should be able to handle a huge raster.
> >> >> r.stream.extract is based on a version of r.watershed that did not
> support yet such huge raster maps, therefore support for such huge raster
> maps needed to be added to r.stream.extract separately.
> >> >> > Anyone know how to over pass this limitation/error ?
> >> >> Please use the latest GRASS 7.2 or GRASS 7.3 version from svn.
> >> >> Markus M
> >> >> > Thank you
> >> >> > Best
> >> >> > Giuseppe Amatulli, Ph.D.
> >> >> > Research scientist at
> >> >> > Yale School of Forestry & Environmental Studies
> >> >> > Yale Center for Research Computing
> >> >> > Center for Science and Social Science Information
> >> >> > New Haven, 06511
> >> >> > Teaching: http://spatial-ecology.org
> >> >> > Work:  https://environment.yale.edu/profile/giuseppe-amatulli/
> >> >> > _______________________________________________
> >> >> > grass-user mailing list
> >> >> > grass-user at lists.osgeo.org
> >> >> > https://lists.osgeo.org/mailman/listinfo/grass-user
> >> > New Haven, 06511
> > New Haven, 06511
New Haven, 06511
Teaching: http://spatial-ecology.net
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20171108/b7b50243/attachment-0001.html>
