[GRASS-user] Import and reproject COSMO REA6 data set
Markus Metz
markus.metz.giswork at gmail.com
Tue Nov 7 12:45:05 PST 2017
On Mon, Nov 6, 2017 at 2:05 PM, Helmut Kudrnovsky <hellik at web.de> wrote:
> Pietro Zambelli wrote
> > Dear Helmut,
> > On 06/11/17 08:22, Helmut Kudrnovsky wrote:
> >> not really an answer, but the data documentation says:
> >> "Output format: GRIB 1, rotated spherical"
> >> a quick web search shows some hints to handle such data.
> > Looking at the reference model manual:
http://www.cosmo-model.org/content/model/documentation/core/cosmoDyncsNumcs.pdf
> > at page 25, there are some equation to transform the rotated spherical
> > coordinates back and forward, see the attached image.
> > Are these the hints that you mentioned in your previous reply?
> > Should I convert the raster in to a x_s, y_s, z list of points and write
> > a function to convert the spherical coordinates (x_s, y_s) values
> > defining my own python script to apply the transformation function and
> > generate the lat, lon, z triplet of values, to be imported into a WGS84
> > location?
> > Any better approach/idea?
> > Thank you for the support.
> never used such kind of data for myself; maybe it would be worth to ask on
> the GDAL ML how to used this kind of data.
GDAL and GRASS use proj4 for reprojection, but proj4 does not support these
rotated spheres where the latitude origin for a longlat projection is not
0. The easiest solution is to use a different data source. Otherwise you
would have to write a reprojection routine for such rotated spheres. The
source code of gdalwarp or r.proj could be used as a template.
Markus M
> some other things I've found in the web, e.g.
https://gis.stackexchange.com/questions/10808/manually-transforming-rotated-lat-lon-to-regular-lat-lon
https://gis.stackexchange.com/questions/64210/transforming-regular-lat-lon-to-rotated-lat-lon
> http://jgrib.sourceforge.net/docs/rotLatLon.pdf
> they looks similar you've found.
> best regards
> Helmut
> Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20171107/b5cef597/attachment.html>
