[GRASS-user] cannot write raster w/ max = inf
Ken Mankoff mankoff at gmail.com
Fri Nov 10 22:24:18 PST 2017
On 2017-11-10 at 23:37, Markus Neteler <neteler at osgeo.org> wrote:
> gdalinfo -mm your_raster_map
I can post the full output, but I assume the part you are interested is the diff between the normal and the '-mm' option, which is:
    Computed Min/Max=0.380,inf
Which are the values reported by ~r.info~.
It may be a bug with the upstream producer. If inf is invalid, I can let them know. I have not seen mention of inf anywhere online (searching GeoTIFF, GDAL, or GRASS), but it makes it hard to search because INF is a file format.
  -k.
