[GRASS-user] v.voronoi error: Found 0 points/centroids, but at least 2 are needed
Markus Neteler
neteler at osgeo.org
Sat Nov 25 04:48:25 PST 2017
On Nov 25, 2017 11:48 AM, "Markus Metz" <markus.metz.giswork at gmail.com>
wrote:
> On Sat, Nov 25, 2017 at 3:07 AM, 洪朝貴 <ckhung at cyut.edu.tw> wrote:
> > Did I miss some steps before calling v.voronoi?
> v.voronoi uses the current region (the algorithm requires this),
therefore you need to set an appropriate computational region first, e.g.
with
> g.region -pa vect=tkec res=1
> before using v.voronoi.
Would it make sense to print the used region settings to help the user?
Best,
markusN
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20171125/48123856/attachment.html>
