[GRASS-user] error in v.in.ogr with null values
Ken Mankoff mankoff at gmail.com
Fri Oct 20 02:33:16 PDT 2017
Hello,
Has a bug been filed for this? I'm having trouble finding it on the Trac
site. I've just run into this issue also. The homebrew install GRASS lets
me import a raster that the MacPorts installation does not. It appears to
be this same bug. If there is no bug report, I'll file one.
  -k.
On Fri, Aug 18, 2017 at 9:10 AM, Moritz Lennert <
mlennert at club.worldonline.be> wrote:
> On 17/08/17 09:07, Mira Kattwinkel wrote:
>> Dear Jonas,
>> thanks for your suggestion.
>> This looks like a useful workaround but it seems to be a more general
>> issue. Is it a wanted behaviour that it is not possible without tricks
>> to import shapes with empty table cells? As I wrote, it used to work
>> just fine.
> I agree that this should "just work". Could you post a bug report, ideally
> with a reproducible example / example data ?
> Moritz
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20171020/611ec4e2/attachment.html>
