[GRASS-user] large shapefile not importing properly with v.import
Helmut Kudrnovsky hellik at web.de
Sat Oct 21 01:54:58 PDT 2017
Ken Mankoff wrote
> On 2017-10-20 at 18:22, Helmut Kudrnovsky <
> hellik@
> > wrote:
>> try to use v.in.ogr instead in a location with the original projection
>> and then reproject it.
> If I import into its native projection with ~v.in.ogr~ it displays fine.
> If I then reproject with ~v.proj~, data is once again dropped.
> ~v.in.ogr~ complained about overlaps, which I don't think should exist,
> even if they are valid in theory. I am currently re-importing with
> ~snap=1E-13~ as suggested by ~v.in.ogr~, but that is taking a few hours.
> Anyway, it seems likely the reprojection won't work in this case either.
> I find it strange that QGIS handles this both instantly and correctly (at
> least correctly based on a cursory visual examination).
>   -k.
QGIS doesn't use a topological data model when it displays such data; GRASS
tries to rebuild correct topology when importing such data; that's may be
the difference.
Have you tried to reproject your data with ogr2ogr?
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
