[GRASS-user] GRASS on High Sierra
Carlos Grohmann
carlos.grohmann at gmail.com
Mon Oct 23 08:55:00 PDT 2017
Hello Stu
I'm still with Sierra but I use homebrew to install GRASS. I also had some
issues with wxpython, and to fix it I had to add this to bash_profile:
export
PYTHONPATH=/usr/local/lib/python2.7/site-packages:/usr/local/lib/python2.7/site-packages/wx-3.0-osx_cocoa:$PYTHONPATH
hope it helps
Carlos
On Mon, Oct 23, 2017 at 1:41 PM, Stuart Edwards <sedwards2 at cinci.rr.com>
wrote:
> Hi --
> A few days ago I upgraded the operating system on my MacBook Pro from
> 10.11 to 10.13 (High Sierra). Most everything seems to still be working -
> except GRASS and QGIS. I have been running Barton's binaries and Kyngs's
> frameworks for a number of years without any major problems. I have 3
> GRASS versions installed - 6.4.5, 7.3 (py2), and 7.3 (py3). 6.4 gives the
> most succinct error messages on startup and it's possible to continue on
> the command line (no gui):
> dyld: Library not loaded: /Applications/GRASS/GRASS-6.4.
> app/Contents/MacOS/lib/libgrass_gis.6.4.5svn.dylib
> Referenced from: /Applications/GRASS-6.4.app/Contents/MacOS/bin/g.gisenv
> Reason: image not found
> The library in question is still where it's always been.
> 7.3 is more verbose, but basically says the same thing:
> Starting GRASS GIS...
> dyld: Library not loaded: /Applications/GRASS-7.3.app/
> Contents/MacOS/lib/libgrass_gis.7.3.svn.dylib
> Referenced from: /Applications/GRASS-7.3_py3.app/Contents/MacOS/bin/g.
> gisenv
> Traceback (most recent call last):
> File "/Applications/GRASS-7.3_py3.app/Contents/MacOS/gui/wxpython/gis_set.py",
> line 31, in <module>
> from core import globalvar
> grass.exceptions.CalledModuleError: Module run None ['g.gisenv', '-n']
> ended with error
> Process ended with non-zero return code -6. See errors in the (error)
> output.
> ERROR: Error in GUI startup. See messages above (if any) and if necessary,
> please report this error to the GRASS developers.
> On systems with package manager, make sure you have the right GUI package,
> probably named grass-gui, installed.
> To run GRASS GIS in text mode use the -text flag.
> Exiting...
> logout
> I tried a fresh installation of 7.3 using macports (grass7) and strangely,
> had a failure where wxWidgets could not be found:
> ---> Attempting to fetch wxWidgets-3.0.3.tar.bz2 from
> https://pek.cn.distfiles.macports.org/macports/distfiles/wxWidgets/3.0.2
> http://ncu.dl.sourceforge.net/project/wxwindows/3.0.2
> http://netcologne.dl.sourceforge.net/project/wxwindows/3.0.2
> http://biolpc22.york.ac.uk/pub/3.0.2/
> http://her.gr.distfiles.macports.org/wxWidgets/3.0.2
> Error: Failed to fetch wxPython-3.0: The requested URL returned error: 404
> Not Found
> Error: See /opt/local/var/macports/logs/_opt_local_var_macports_
> sources_rsync.macports.org_release_tarballs_ports_graphics_wxWidgets-3.0/wxPython-3.0/main.log
> for details.
> Error: Follow https://guide.macports.org/#project.tickets to report a bug.
> Error: Processing of port grass7 failed
> Macports attempted to fetch wxWidgets from all its sources. But the
> currently installed (and considered up to date) version is wxWidgets-3.0.3
> - strange.
> So there does appear to be something unusual going on with wxpython and OS
> X 10.13
> The bad news may be that there is currently no source of a binary version
> of GRASS for anyone with a new Mac or upgrading their OS. I did get the
> Macports version of QGIS to install and run - but I need my GRASS to run !
> Happy to pursue this further if anyone has any ideas to try .......
> thx
> Stu
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
Prof. Carlos Henrique Grohmann
Institute of Energy and Environment - Univ. of São Paulo, Brazil
- Digital Terrain Analysis | GIS | Remote Sensing -
http://carlosgrohmann.com
http://orcid.org/0000-0001-5073-5572
________________
Can’t stop the signal.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20171023/a0f07ce3/attachment.html>
