[GRASS-user] GRASS on High Sierra
Stuart Edwards
sedwards2 at cinci.rr.com
Mon Oct 23 13:34:50 PDT 2017
thanks -
that worked - yesterday I didn't make it past the downloads page and so didn't catch on to the new homebrew pages - may need to add a link on the downloads page.
Best
Stu
> On Oct 23, 2017, at 1:24 PM, Carlos Grohmann <carlos.grohmann at gmail.com <mailto:carlos.grohmann at gmail.com>> wrote:
> You need to "tap" the osgeo repository:
> https://grasswiki.osgeo.org/wiki/Compiling_on_MacOSX_using_homebrew <https://grasswiki.osgeo.org/wiki/Compiling_on_MacOSX_using_homebrew>
> Carlos
> On Mon, Oct 23, 2017 at 2:33 PM, Stuart Edwards <sedwards2 at cinci.rr.com <mailto:sedwards2 at cinci.rr.com>> wrote:
> Carlos
> Thanks for the quick response.... Unfortunately that did not cure the problem. You say you are using homebrew - that was my first choice, but I don't see GRASS in their package list - am I missing something?
> Stu
>> On Oct 23, 2017, at 11:55 AM, Carlos Grohmann <carlos.grohmann at gmail.com <mailto:carlos.grohmann at gmail.com>> wrote:
>> Hello Stu
>> I'm still with Sierra but I use homebrew to install GRASS. I also had some issues with wxpython, and to fix it I had to add this to bash_profile:
>> export PYTHONPATH=/usr/local/lib/python2.7/site-packages:/usr/local/lib/python2.7/site-packages/wx-3.0-osx_cocoa:$PYTHONPATH
>> hope it helps
>> Carlos
>> On Mon, Oct 23, 2017 at 1:41 PM, Stuart Edwards <sedwards2 at cinci.rr.com <mailto:sedwards2 at cinci.rr.com>> wrote:
>> Hi --
>> A few days ago I upgraded the operating system on my MacBook Pro from 10.11 to 10.13 (High Sierra). Most everything seems to still be working - except GRASS and QGIS. I have been running Barton's binaries and Kyngs's frameworks for a number of years without any major problems. I have 3 GRASS versions installed - 6.4.5, 7.3 (py2), and 7.3 (py3). 6.4 gives the most succinct error messages on startup and it's possible to continue on the command line (no gui):
>> dyld: Library not loaded: /Applications/GRASS/GRASS-6.4.app/Contents/MacOS/lib/libgrass_gis.6.4.5svn.dylib
>> Referenced from: /Applications/GRASS-6.4.app/Contents/MacOS/bin/g.gisenv
>> Reason: image not found
>> The library in question is still where it's always been.
>> 7.3 is more verbose, but basically says the same thing:
>> Starting GRASS GIS...
>> dyld: Library not loaded: /Applications/GRASS-7.3.app/Contents/MacOS/lib/libgrass_gis.7.3.svn.dylib
>> Referenced from: /Applications/GRASS-7.3_py3.app/Contents/MacOS/bin/g.gisenv
>> Traceback (most recent call last):
>> File "/Applications/GRASS-7.3_py3.app/Contents/MacOS/gui/wxpython/gis_set.py", line 31, in <module>
>> from core import globalvar
>> grass.exceptions.CalledModuleError: Module run None ['g.gisenv', '-n'] ended with error
>> Process ended with non-zero return code -6. See errors in the (error) output.
>> ERROR: Error in GUI startup. See messages above (if any) and if necessary, please report this error to the GRASS developers.
>> On systems with package manager, make sure you have the right GUI package, probably named grass-gui, installed.
>> To run GRASS GIS in text mode use the -text flag.
>> Exiting...
>> logout
>> I tried a fresh installation of 7.3 using macports (grass7) and strangely, had a failure where wxWidgets could not be found:
>> ---> Attempting to fetch wxWidgets-3.0.3.tar.bz2 from https://pek.cn.distfiles.macports.org/macports/distfiles/wxWidgets/3.0.2 <https://pek.cn.distfiles.macports.org/macports/distfiles/wxWidgets/3.0.2>
>> ---> Attempting to fetch wxWidgets-3.0.3.tar.bz2 from http://ncu.dl.sourceforge.net/project/wxwindows/3.0.2 <http://ncu.dl.sourceforge.net/project/wxwindows/3.0.2>
>> ---> Attempting to fetch wxWidgets-3.0.3.tar.bz2 from http://netcologne.dl.sourceforge.net/project/wxwindows/3.0.2 <http://netcologne.dl.sourceforge.net/project/wxwindows/3.0.2>
>> ---> Attempting to fetch wxWidgets-3.0.3.tar.bz2 from http://biolpc22.york.ac.uk/pub/3.0.2/ <http://biolpc22.york.ac.uk/pub/3.0.2/>
>> ---> Attempting to fetch wxWidgets-3.0.3.tar.bz2 from http://her.gr.distfiles.macports.org/wxWidgets/3.0.2 <http://her.gr.distfiles.macports.org/wxWidgets/3.0.2>
>> Error: Failed to fetch wxPython-3.0: The requested URL returned error: 404 Not Found
>> Error: See /opt/local/var/macports/logs/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_graphics_wxWidgets-3.0/wxPython-3.0/main.log for details.
>> Error: Follow https://guide.macports.org/#project.tickets <https://guide.macports.org/#project.tickets> to report a bug.
>> Error: Processing of port grass7 failed
>> Macports attempted to fetch wxWidgets from all its sources. But the currently installed (and considered up to date) version is wxWidgets-3.0.3 - strange.
>> So there does appear to be something unusual going on with wxpython and OS X 10.13
>> The bad news may be that there is currently no source of a binary version of GRASS for anyone with a new Mac or upgrading their OS. I did get the Macports version of QGIS to install and run - but I need my GRASS to run !
>> Happy to pursue this further if anyone has any ideas to try .......
>> thx
>> Stu
>> grass-user mailing list
>> grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
>> https://lists.osgeo.org/mailman/listinfo/grass-user <https://lists.osgeo.org/mailman/listinfo/grass-user>
>> Prof. Carlos Henrique Grohmann
>> Institute of Energy and Environment - Univ. of São Paulo, Brazil
>> - Digital Terrain Analysis | GIS | Remote Sensing -
>> http://carlosgrohmann.com <http://carlosgrohmann.com/>
>> http://orcid.org/0000-0001-5073-5572 <http://orcid.org/0000-0001-5073-5572>
>> ________________
>> Can’t stop the signal.
> ________________
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20171023/bdd39fa1/attachment.html>
