[GRASS-user] GRASS on High Sierra
Ken Mankoff
mankoff at gmail.com
Sun Oct 29 13:28:43 PDT 2017
I'm on Sierra and GRASS from Homebrew worked well for me (tap osgeo to
access it). But I recently removed homebrew to switch to MacPorts. GRASS
did not work for me from MacPorts. I don't recall if it was the same
wxwidgets error you report above. I now run GRASS and QGIS from fink,
co-installed with MacPorts which I use for most of the rest of my *nix
tools. The two do play fine together - no problems so far. I needed
macports to get the good version of the emacs-mac package.
-k.
On Mon, Oct 23, 2017 at 10:34 PM, Stuart Edwards <sedwards2 at cinci.rr.com>
wrote:
> thanks -
> that worked - yesterday I didn't make it past the downloads page and so
> didn't catch on to the new homebrew pages - may need to add a link on the
> downloads page.
> Best
> Stu
> On Oct 23, 2017, at 1:24 PM, Carlos Grohmann <carlos.grohmann at gmail.com>
> wrote:
> You need to "tap" the osgeo repository:
> https://grasswiki.osgeo.org/wiki/Compiling_on_MacOSX_using_homebrew
> Carlos
> On Mon, Oct 23, 2017 at 2:33 PM, Stuart Edwards <sedwards2 at cinci.rr.com>
> wrote:
>> Carlos
>> Thanks for the quick response.... Unfortunately that did not cure the
>> problem. You say you are using homebrew - that was my first choice, but I
>> don't see GRASS in their package list - am I missing something?
>> Stu
>> On Oct 23, 2017, at 11:55 AM, Carlos Grohmann <carlos.grohmann at gmail.com>
>> wrote:
>> Hello Stu
>> I'm still with Sierra but I use homebrew to install GRASS. I also had
>> some issues with wxpython, and to fix it I had to add this to bash_profile:
>> export PYTHONPATH=/usr/local/lib/python2.7/site-packages:/usr/local
>> /lib/python2.7/site-packages/wx-3.0-osx_cocoa:$PYTHONPATH
>> hope it helps
>> Carlos
>> On Mon, Oct 23, 2017 at 1:41 PM, Stuart Edwards <sedwards2 at cinci.rr.com>
>> wrote:
>>> Hi --
>>> A few days ago I upgraded the operating system on my MacBook Pro from
>>> 10.11 to 10.13 (High Sierra). Most everything seems to still be working -
>>> except GRASS and QGIS. I have been running Barton's binaries and Kyngs's
>>> frameworks for a number of years without any major problems. I have 3
>>> GRASS versions installed - 6.4.5, 7.3 (py2), and 7.3 (py3). 6.4 gives the
>>> most succinct error messages on startup and it's possible to continue on
>>> the command line (no gui):
>>> dyld: Library not loaded: /Applications/GRASS/GRASS-6.4.
>>> app/Contents/MacOS/lib/libgrass_gis.6.4.5svn.dylib
>>> Referenced from: /Applications/GRASS-6.4.app/Co
>>> ntents/MacOS/bin/g.gisenv
>>> Reason: image not found
>>> The library in question is still where it's always been.
>>> 7.3 is more verbose, but basically says the same thing:
>>> Starting GRASS GIS...
>>> dyld: Library not loaded: /Applications/GRASS-7.3.app/Co
>>> ntents/MacOS/lib/libgrass_gis.7.3.svn.dylib
>>> Referenced from: /Applications/GRASS-7.3_py3.ap
>>> p/Contents/MacOS/bin/g.gisenv
>>> Traceback (most recent call last):
>>> File "/Applications/GRASS-7.3_py3.app/Contents/MacOS/gui/wxpython/gis_set.py",
>>> line 31, in <module>
>>> from core import globalvar
>>> grass.exceptions.CalledModuleError: Module run None ['g.gisenv', '-n']
>>> ended with error
>>> Process ended with non-zero return code -6. See errors in the (error)
>>> output.
>>> ERROR: Error in GUI startup. See messages above (if any) and if
>>> necessary, please report this error to the GRASS developers.
>>> On systems with package manager, make sure you have the right GUI
>>> package, probably named grass-gui, installed.
>>> To run GRASS GIS in text mode use the -text flag.
>>> Exiting...
>>> logout
>>> I tried a fresh installation of 7.3 using macports (grass7) and
>>> strangely, had a failure where wxWidgets could not be found:
>>> ---> Attempting to fetch wxWidgets-3.0.3.tar.bz2 from
>>> https://pek.cn.distfiles.macports.org/macports/distfiles/wxWidgets/3.0.2
>>> http://ncu.dl.sourceforge.net/project/wxwindows/3.0.2
>>> http://netcologne.dl.sourceforge.net/project/wxwindows/3.0.2
>>> http://biolpc22.york.ac.uk/pub/3.0.2/
>>> http://her.gr.distfiles.macports.org/wxWidgets/3.0.2
>>> Error: Failed to fetch wxPython-3.0: The requested URL returned error:
>>> 404 Not Found
>>> Error: See /opt/local/var/macports/logs/_opt_local_var_macports_sources
>>> _rsync.macports.org_release_tarballs_ports_graphics_wxWidgets-3.0/wxPython-3.0/main.log
>>> for details.
>>> Error: Follow https://guide.macports.org/#project.tickets to report a
>>> bug.
>>> Error: Processing of port grass7 failed
>>> Macports attempted to fetch wxWidgets from all its sources. But the
>>> currently installed (and considered up to date) version is wxWidgets-3.0.3
>>> - strange.
>>> So there does appear to be something unusual going on with wxpython and
>>> OS X 10.13
>>> The bad news may be that there is currently no source of a binary
>>> version of GRASS for anyone with a new Mac or upgrading their OS. I did
>>> get the Macports version of QGIS to install and run - but I need my GRASS
>>> to run !
>>> Happy to pursue this further if anyone has any ideas to try .......
>>> thx
>>> Stu
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/grass-user
>> Prof. Carlos Henrique Grohmann
>> Institute of Energy and Environment - Univ. of São Paulo, Brazil
>> - Digital Terrain Analysis | GIS | Remote Sensing -
>> http://carlosgrohmann.com
>> http://orcid.org/0000-0001-5073-5572
>> ________________
>> Can’t stop the signal.
> ________________
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20171029/3fea705e/attachment.html>
