[GRASS-user] Unable to open the Corine land cover map using GrassGIS 7
Helmut Kudrnovsky
hellik at web.de
Tue Oct 24 08:15:10 PDT 2017
Veronica Andreo wrote
> Hi,
> I'm facing this same problem...
> I have my EPSG:3035 location and when using r.import with -o flag to
> override projection check and import corine land cover, I get:
> GRASS 7.3.svn (eu_laea):~> r.import -o input=g250_clc06_V18_5.tif
> output=clc06_V18_5_250m resample=nearest extent=region resolution=value
> resolution_value=250 title="Corine Land Cover 2006 - 250m - V18.5"
> ERROR: Unable to convert input map projection to GRASS format; cannot
> create new location.
> ERROR: Unable to read GDAL dataset
> <g250_clc06_V18_5.tif>
> while -o flag is supposed to override the check and import. This used to
> work before. Am I missunderstanding something here?
confirmed
r.import input=D:\dl\ne\g250_clc12_V18_5a\g250_clc12_V18_5.tif
output=g250_clc12_V18_5 -o
ERROR: Unable to convert input map projection to GRASS format; cannot create
new location.
<D:\dl\ne\g250_clc12_V18_5a\g250_clc12_V18_5.tif>
where does 'cannot create new location' comes from?
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
