[GRASS-user] Unable to open the Corine land cover map using GrassGIS 7
Helmut Kudrnovsky
hellik at web.de
Tue Oct 24 08:20:44 PDT 2017
Helmut Kudrnovsky wrote
> Veronica Andreo wrote
>> Hi,
>> I'm facing this same problem...
>> I have my EPSG:3035 location and when using r.import with -o flag to
>> override projection check and import corine land cover, I get:
>> GRASS 7.3.svn (eu_laea):~> r.import -o input=g250_clc06_V18_5.tif
>> output=clc06_V18_5_250m resample=nearest extent=region resolution=value
>> resolution_value=250 title="Corine Land Cover 2006 - 250m - V18.5"
>> ERROR: Unable to convert input map projection to GRASS format; cannot
>> create new location.
>> ERROR: Unable to read GDAL dataset
> <g250_clc06_V18_5.tif>
>> while -o flag is supposed to override the check and import. This used to
>> work before. Am I missunderstanding something here?
> confirmed
> r.import input=D:\dl\ne\g250_clc12_V18_5a\g250_clc12_V18_5.tif
> output=g250_clc12_V18_5 -o
> create
> new location.
> <D:\dl\ne\g250_clc12_V18_5a\g250_clc12_V18_5.tif>
> where does 'cannot create new location' comes from?
grass7.2.2
r.in.gdal -o input=D:\dl\ne\g250_clc12_V18_5a\g250_clc12_V18_5.tif
output=fhfghgfh
WARNING: Over-riding projection check
Proceeding with import of 1 raster bands...
Importing raster map <fhfghgfh>...
grass7.3.svn
output=sgdfg
Input contains an invalid SRS. WKT definition:
LOCAL_CS["Geocoding information not available Projection Name =
ETRS_1989_LAEA Units = meters GeoTIFF Units = ot",UNIT["unknown",1]]
WARNING: Unable to convert input map projection information to GRASS format.
Importing raster map <sgdfg>...
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
