[GRASS-user] Unusual [Open|ESRI]FileGDB: how to import
Rich Shepard
rshepard at appl-ecosys.com
Fri Oct 27 05:45:13 PDT 2017
On Fri, 27 Oct 2017, Markus Metz wrote:
> Instead of manually creating a proj.4 definition, you can use v.in.ogr
> in=BullTrout_201201_v931.gdb location=bulltrout_location -i
> to create a location from that gdb. If you don't use the -i flag, the data
> will also be imported into the new location.
> With GRASS 7.3, v.in.ogr will report back if there are any problems with
> the included SRS, or if no SRS is available for the selected layer.
Markus,
This is a better approach and I appreciate learning it.
Thanks,
Rich
