[GRASS-user] Unusual [Open|ESRI]FileGDB: how to import
Rich Shepard
rshepard at appl-ecosys.com
Mon Oct 30 08:35:05 PDT 2017
On Fri, 27 Oct 2017, Markus Metz wrote:
> Instead of manually creating a proj.4 definition, you can use
> v.in.ogr in=BullTrout_201201_v931.gdb location=bulltrout_location -i
> to create a location from that gdb. If you don't use the -i flag, the data
> will also be imported into the new location.
> With GRASS 7.3, v.in.ogr will report back if there are any problems with
> the included SRS, or if no SRS is available for the selected layer.
Markus,
I'm importing all species into their own locations; will combine later.
The above command worked (so far) with four species, but on one it threw a
seqfault:
GRASS 7.3.svn (Fish):~/data/grassdata > v.in.ogr in=~/data/species/fish/RedbandTrout_201201_v931.gdb/ location=redband_trout_loc
WARNING: Updating spatial reference with embedded proj4 definition
WARNING: Datum <unknown> not recognised by GRASS and no parameters found
Segmentation fault
I tried to find the proj4 defintion but have no idea in which file it is
found. I can provide the directory if desired; it's 18M so I could put it on
Dropbox. Or, is there something I can do here to clear the blockage?
Regards,
Rich
