[GRASS-user] r.stream.extract error
Markus Metz
markus.metz.giswork at gmail.com
Tue Oct 31 12:54:36 PDT 2017
On Mon, Oct 30, 2017 at 1:42 PM, Giuseppe Amatulli <
giuseppe.amatulli at gmail.com> wrote:
> Hi,
> I'm using the r.stream.extract grass command
> r.stream.extract elevation=elv accumulation=upa threshold=0.5
depression=dep direction=dir stream_raster=stream memory=35000 --o
--verbose
> where the elv is raster of 142690 * 80490 = 11,485,118,100 cell
> and I get this error
> 12.97% of data are kept in memory
> Will need up to 293.52 GB (300563 MB) of disk space
> Creating temporary files...
> Loading input raster maps...
0..3..6..9..12..15..18..21..24..27..30..33..36..39..42..45..48..51..54..57..60..63..66..69..72..75..78..81..84..87..90..93..96..99..100
> ERROR: Unable to load input raster map(s)
This error is caused by integer overflow because not all variables
necessary to support such large maps were 64 bit integer.
Fixed in trunk and relbr72 with r71620,1, and tested with a DEM with 172800
* 67200 = 11,612,160,000 cells: r.stream.extract finished successfully in
18 hours (not a HPC, a standard desktop maschine with 32 GB of RAM and a
750 GB SSD).
> According to the help manual the memory=35000 should be set in according
to the overall memory available. I set the HPC upper memory limit to 40G.
> I try several combination of these parameters but i still get the same
error.
> If the r.stream.extract is based on r.watershed than the segmentation
library should be able to handle a huge raster.
r.stream.extract is based on a version of r.watershed that did not support
yet such huge raster maps, therefore support for such huge raster maps
needed to be added to r.stream.extract separately.
> Anyone know how to over pass this limitation/error ?
Please use the latest GRASS 7.2 or GRASS 7.3 version from svn.
Markus M
> Thank you
> Best
> Giuseppe Amatulli, Ph.D.
> Research scientist at
> Yale School of Forestry & Environmental Studies
> Yale Center for Research Computing
> Center for Science and Social Science Information
> New Haven, 06511
> Teaching: http://spatial-ecology.org
> Work: https://environment.yale.edu/profile/giuseppe-amatulli/
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20171031/21fcb2a5/attachment.html>
