[GRASS-user] Recovering from a build error
Rich Shepard
rshepard at appl-ecosys.com
Fri Sep 15 09:31:11 PDT 2017
Very infrequently, when building a new executable from updated source code
from the 7.3.svn trunk I'll get an error such as today's:
Errors in:
/home/rshepard/gis/grass/grass7_trunk/scripts/d.rast.edit
In case of errors please change into the directory with error and run 'make'.
When I cd to scripts/ and run make it completes without errors. Because it
has been so long since make has thrown an error I've forgotten how to
proceed. If I 'make distclean' and start over by configuring and making I
get the same error.
Cd'ing back to grass7_trunk/ and running 'make' again still generates an
error in the same file:
GRASS GIS 7.3.svn r71491 compilation log
Started compilation: Fri Sep 15 09:27:55 PDT 2017
Errors in:
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Fri Sep 15 09:28:23 PDT 2017
Makefile:57: recipe for target 'default' failed
make: *** [default] Error 1
A reminder is needed.
TIA,
Rich
