[GRASS-user] Recovering from a build error
AB balotti.and at gmail.com
Sun Sep 17 11:50:15 PDT 2017
Hi Rich,
Not a solution, but you can run the 'make' with the '-i' flag to ignore
errors [1].
After compilation you can manually test d.rast.edit command to see if it
run fine.
[1] https://www.gnu.org/software/make/manual/html_node/Options-Summary.html
Best regards,
Andrea Balotti
Il 15/09/2017 18:31, Rich Shepard ha scritto:
>   Very infrequently, when building a new executable from updated
> source code
> from the 7.3.svn trunk I'll get an error such as today's:
> Errors in:
> /home/rshepard/gis/grass/grass7_trunk/scripts/d.rast.edit
> In case of errors please change into the directory with error and run
> 'make'.
>   When I cd to scripts/ and run make it completes without errors.
> Because it
> has been so long since make has thrown an error I've forgotten how to
> proceed. If I 'make distclean' and start over by configuring and making I
> get the same error.
>   Cd'ing back to grass7_trunk/ and running 'make' again still
> generates an
> error in the same file:
> GRASS GIS 7.3.svn r71491 compilation log
> Started compilation: Fri Sep 15 09:27:55 PDT 2017
> Errors in:
> 'make'.
> If you get multiple errors, you need to deal with them in the order they
> appear in the error log. If you get an error building a library, you will
> also get errors from anything which uses the library.
> Finished compilation: Fri Sep 15 09:28:23 PDT 2017
> Makefile:57: recipe for target 'default' failed
> make: *** [default] Error 1
>   A reminder is needed.
> TIA,
> Rich
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
