[GRASS-user] Recovering from a build error
Rich Shepard
rshepard at appl-ecosys.com
Sun Sep 17 12:09:04 PDT 2017
On Sun, 17 Sep 2017, AB wrote:
> Not a solution, but you can run the 'make' with the '-i' flag to ignore
> errors [1].
> After compilation you can manually test d.rast.edit command to see if it run
> fine.
> [1] https://www.gnu.org/software/make/manual/html_node/Options-Summary.html
Andrea,
Thanks. I may try that. I've run grass since 4.0 and this is the first
time I've hit an error that won't fix.
I'll do another 'svn up' and see if that fixes the issue.
Best regards,
Rich
