[GRASS-user] Creating new mapsets in current location
Helmut Kudrnovsky hellik at web.de
Sun Sep 24 12:25:35 PDT 2017
Rich Shepard wrote
> The g.mapset man page confirms the way I've been using it: change to
> another mapset in the current location. However, I need to re-project maps
> existing in a different location.
>    I've tried using it to create a new mapset in the current location (by
> checking the box 'create mapset if it doesn't exist') but the name of a
> mapset in the current location is required. The mapset does not yet exist
> and I'm confused why there is an option to create it if it must already
> exist.
>    After re-projecting each mapset from the -feet to the -meters locations
> I
> exit grass, then reload it after defining a new mapset name.
>    Is there a better way to do this?
just tried here with
g.mapset -p
data
g.mapset -c mapset=t
g.mapset -p
t
g.mapset - Changes/reports current mapset.
Optionally create new mapset or list available mapsets in given location.
here it works: change to mapset t which should be created.
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
