[GRASS-user] OpenFileGDB input error
Moritz Lennert
mlennert at club.worldonline.be
Mon Sep 25 01:10:34 PDT 2017
Le Sun, 24 Sep 2017 13:18:34 -0700 (PDT),
Rich Shepard <rshepard at appl-ecosys.com> a écrit :
> On Sun, 24 Sep 2017, Rich Shepard wrote:
> > Using the GUI I ran v.in.ogr, specifying the directory in which
> > the file is found (the location uses the final EPSG reported when
> > 'ogrinfo -al -so' was run with output directed to a file), the
> > format, and clicked the single layer in the Input tab. This is the
> > displayed error message:
> > (Sun Sep 24 11:59:03 2017) v.in.ogr
> > input=/home/rshepard/data/grassdata/wash-state-data/farmland/2016WSDACropDistribution.gdb
> > layer=WSDACrop_2016
> > Check if OGR layer <WSDACrop_2016> contains polygons...
> > Importing 198132 features
> > Importing 198132 features (OGR layer <WSDACrop_2016>)...
> > ERROR: Unknown geometry type
> > (Sun Sep 24 11:59:59 2017) Command finished (55 sec)
> More information I should have included. From the ogrinfo metadata:
> Layer name: WSDACrop_2016
> Geometry: Multi Polygon
> Feature Count: 198132
> What does GRASS call 'Multi Polygon'?
I can't answer that, but what happens when you run ogr2ogr on the
layer to transform it into a GeoPackage or a Shapefile ?
Moritz
