[GRASS-user] OpenFileGDB input error
Moritz Lennert
mlennert at club.worldonline.be
Mon Sep 25 07:32:37 PDT 2017
[Please keep discussions on the list.]
On 25/09/17 16:19, Rich Shepard wrote:
> On Mon, 25 Sep 2017, Moritz Lennert wrote:
>> I can't answer that, but what happens when you run ogr2ogr on the layer to
>> transform it into a GeoPackage or a Shapefile?
> Moritz,
> I've not before used ogr2ogr and reading the man page leaves me uncertain
> which options I should use other than the destination and source formats.
> This is the summary of the source .gdb:
> Layer name: WSDACrop_2016
> Geometry: Multi Polygon
> Feature Count: 198132
> Extent: (194040.798600, 26290.144100) - (776078.287500, 411036.825500)
> Layer SRS WKT:
> PROJCS["NAD83(HARN) / Washington South",
> GEOGCS["NAD83(HARN)",
> DATUM["NAD83_High_Accuracy_Reference_Network",
> SPHEROID["GRS 1980",6378137,298.257222101,
> AUTHORITY["EPSG","7019"]],
> TOWGS84[0,0,0,0,0,0,0],
> AUTHORITY["EPSG","6152"]],
> PRIMEM["Greenwich",0,
> AUTHORITY["EPSG","8901"]],
> UNIT["degree",0.0174532925199433,
> AUTHORITY["EPSG","9122"]],
> AUTHORITY["EPSG","4152"]],
> PROJECTION["Lambert_Conformal_Conic_2SP"],
> PARAMETER["standard_parallel_1",47.33333333333334],
> PARAMETER["standard_parallel_2",45.83333333333334],
> PARAMETER["latitude_of_origin",45.33333333333334],
> PARAMETER["central_meridian",-120.5],
> PARAMETER["false_easting",500000],
> PARAMETER["false_northing",0],
> UNIT["metre",1,
> AUTHORITY["EPSG","9001"]],
> AXIS["X",EAST],
> AXIS["Y",NORTH],
> AUTHORITY["EPSG","2856"]]
> FID Column = OBJECTID
> Geometry Column = SHAPE
> CropGroup: String (254.0)
> Acres: Integer (0.0)
> Irrigation: String (254.0)
> InitialSurveyDate: DateTime (0.0)
> LastSurveyDate: DateTime (0.0)
> DataSource: String (254.0)
> Notes: String (254.0)
> TRS: String (15.0)
> County: String (254.0)
> RotCropType: String (254.0)
> ExactAcres: Real (0.0)
> Organic: String (3.0)
> SHAPE_Length: Real (0.0)
> SHAPE_Area: Real (0.0)
> Layer name: CropData
> Geometry: None
> Layer SRS WKT:
> (unknown)
> TRS: String (15.0)
> The error after the ogr first pass is "ERROR: Unknown geometry type"
This is with what command line ?
> Do I run ogr2ogr with no options specifying the same file name with
> extension .shp for the destination and with the extension .gdb for the
> source?
You can use whatever filename you want, but this should work, yes.
Moritz
