[GRASS-user] r.sun.daily ouputs
Anna Petrášová kratochanna at gmail.com
Sat Sep 30 14:59:42 PDT 2017
I hopefully fixed that problem in r71516, please test it once the
addon is available for Windows, which should be tomorrow or Monday.
Anna
On Fri, Sep 29, 2017 at 8:20 AM, Anna Petrášová <kratochanna at gmail.com> wrote:
> Hi,
> On Sep 29, 2017 3:16 AM, <balotti.and at gmail.com> wrote:
> Hi Anna,
> Here the test on NC dataset, I reduced a little bit the resolution to
> speedup computation:
> g.region raster=elevation res=30 -p
> r.resamp.interp input=elevation at PERMANENT output=dem30
> r.slope.aspect elevation=dem30 at PERMANENT slope=slo aspect=asp
> r.sun.daily -t elevation=dem30 at PERMANENT aspect=asp at PERMANENT
> slope=slo at PERMANENT start_day=91 end_day=304 glob_rad=sol_glob
> glob_rad_basename=sol nprocs=4
> t.rast.series input=sol at PERMANENT method=sum output=sol_sum
> And the output querying on a random pixel is:
> est, nord: 636522.196262, 219573.598131
> sol_glob at PERMANENT: value: 28270.75
> sol_sum at PERMANENT: value: 1632588.35400391
> The only thing that could create problem maybe is that during the execution
> of r.sun.daily I received many warnings like this (translated: can't rename
> file NULL/CELL)
> WARNING: Non riesco a rinominare il file null
> 'C:\...\GRASS_data\nc_basic_spm_grass7\PERMANENT\.tmp/unknown\4860.1' in
> 'C:\...\GRASS_data\nc_basic_spm_grass7\PERMANENT\cell_misc\sol_glob\null':
> File exists
> WARNING: Non riesco a rinominare il file cella
> 'C:\...\GRASS_data\nc_basic_spm_grass7\PERMANENT\.tmp/unknown\4860.0' in
> 'C:\...\GRASS_data\nc_basic_spm_grass7\PERMANENT\fcell\sol_glob': File
> exists
> Since sum by r.sun.daily is less than sum by t.rast.series, maybe the summed
> file is not properly summed and represent just the sum of the last days of
> the period?
> P.S. I am on Windows with GRASS 7.2.1
> That is helpful, thanks, I think I know what might be wrong looking at the
> code. It apparently works on Linux, but not on Windows. I don't have time
> today, but will fix it as soon as possible. Thank you!
> Anna
> Andrea Balotti
> Il 28/09/2017 19:00, Anna Petrášová ha scritto:
> Hi,
> On Thu, Sep 28, 2017 at 5:30 AM,  <balotti.and at gmail.com> wrote:
> Hi,
> I am using  r.sun.daily to perform global radiation maps over a range of
> dates but I am a little bit confused about the outputs of this module.
> I created two outputs: the accumulated map of the whole time period and a
> temporal dataset with all the daily maps.
> I have tried to aggregate the daily maps in the temporal dataset with
> t.rast.series (average and sum) supposing that one of them was the same with
> the accumulated output of r.sun.daily but I was wrong.
> Here the query on a pixel: the first line is the accumulated map from
> r.sun.daily, the last two line are the aggregated maps from t.rast.series.
> sol_glob_veg at PERMANENT: value: 24291.95
> sol_veg_sum at PERMANENT: value: 1495683.87133789
> sol_veg_avg at PERMANENT: value: 6989.17696886865
> My question now is which kind of accumulation perform r.sun.daily?
> TIA
> it just sums the maps from each day, so t.rast.series with sum should
> give you the same results. I tested it in NC sample datatset and
> indeed it gave me identical results. Could you test it in the sample
> dataset and perhaps send the commands you are using?
> Thank you,
> Anna
> Andrea Balotti
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
