[GRASS-user] problem with g.in.ogr
Markus Metz
markus.metz.giswork at gmail.com
Wed Apr 18 08:30:11 PDT 2018
On Wed, Apr 18, 2018 at 5:27 PM, Camille Bezzina <camille.bezzina at geophom.fr>
wrote:
> Hi,
> I tried to import my vector with the latest version 7.4 and testing
snap=0.01or other values but there is always the same problem.
> I also tried with another shapefile (smaller) but it doen't change
anything.
> You can find the result in the attached file (verbose + .pdf). As you can
see, when I import a .shp, a lot of polygons desappear.
Can you provide off-list (a link to) the shapefile causing problems? Then
we can test.
Markus M
> Camille
> Le 12/04/2018 à 18:20, Moritz Lennert a écrit :
> On 12/04/18 17:03, Camille Bezzina wrote:
> Hi Markus,
> In the file attached you can find the full output of v.import with
verbose.
> I launch this one with v.in.ogr and this is the answer.
> At the end you can see:
> "Some input polygons are overlapping each other.
> If overlapping is not desired, the data need to be cleaned.
> The input could be cleaned by snapping vertices to each other.
> Estimated range of snapping threshold: [1e-08, 1]
> Try to import again, snapping with at least 1e-08: 'snap=1e-08'"
> Try importing with snap=0.01 or something like that (depending on the
nature and precision of your data.
> Moritz
> Thanks.
> Le 12/04/2018 à 16:39, Markus Metz a écrit :
> On Thu, Apr 12, 2018 at 3:04 PM, Camille Bezzina <
camille.bezzina at geophom.fr <mailto:camille.bezzina at geophom.fr>> wrote:
> > Hello all,
> > I have a problem with v.in.ogr.
> > I would like to import a shape file (with 57851 polygons) with v.in.ogr.
> > v.import --verbose
input=/media/hdd1/phom/eolien/AIP_UNESCO_RONCHAMP/data/qgis/MNE/bati_D90_decoupe.shp
layer=bati_D90_decoupe output=bati_D90_decoupe -o
> > Visibly the order is going well, my attribute table contains 57851
attributes but when I check my vector with display, some polygons are
missing.
> Can you post the full output of v.import with --verbose?
> Considering that you override the projection check with -o, you can also
use v.in.ogr directly and then post the full output of v.in.ogr -o
--verbose.
> Markus M
> > Thanks for your help.
> > Camille Bezzina
> > Geophom
> > grass-user mailing list
> > grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
> > https://lists.osgeo.org/mailman/listinfo/grass-user
> Camille BEZZINA
> Chargé d'études géomatiques et photomontages
> Geophom
> 57 rue du Chemin Neuf 44521 OUDON
> Standard: +33(0)2 85 52 02 59
> Ligne directe: +33(0)9 72 56 81 71
> www.geophom.fr
> Camille BEZZINA
> Geophom
> www.geophom.fr
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180418/c3d4190d/attachment.html>
