[GRASS-user] problem with g.in.ogr
Camille Bezzina
camille.bezzina at geophom.fr
Wed Apr 18 08:27:12 PDT 2018
I tried to import my vector with the latest version 7.4 and testing
snap=0.01or other values but there is always the same problem.
I also tried with another shapefile (smaller) but it doen't change
anything.
You can find the result in the attached file (verbose + .pdf). As you
can see, when I import a .shp, a lot of polygons desappear.
Camille
Le 12/04/2018 à 18:20, Moritz Lennert a écrit :
> On 12/04/18 17:03, Camille Bezzina wrote:
>> Hi Markus,
>> In the file attached you can find the full output of v.import with
>> verbose.
>> I launch this one with v.in.ogr and this is the answer.
> At the end you can see:
> "Some input polygons are overlapping each other.
> If overlapping is not desired, the data need to be cleaned.
> The input could be cleaned by snapping vertices to each other.
> Estimated range of snapping threshold: [1e-08, 1]
> Try to import again, snapping with at least 1e-08: 'snap=1e-08'"
> Try importing with snap=0.01 or something like that (depending on the
> nature and precision of your data.
> Moritz
>> Thanks.
>> Le 12/04/2018 à 16:39, Markus Metz a écrit :
>>> On Thu, Apr 12, 2018 at 3:04 PM, Camille Bezzina
>>> <camille.bezzina at geophom.fr <mailto:camille.bezzina at geophom.fr>> wrote:
>>> > Hello all,
>>> > I have a problem with v.in.ogr.
>>> > I would like to import a shape file (with 57851 polygons) with
>>> v.in.ogr.
>>> > v.import --verbose
>>> input=/media/hdd1/phom/eolien/AIP_UNESCO_RONCHAMP/data/qgis/MNE/bati_D90_decoupe.shp
>>> layer=bati_D90_decoupe output=bati_D90_decoupe -o
>>> > Visibly the order is going well, my attribute table contains 57851
>>> attributes but when I check my vector with display, some polygons
>>> are missing.
>>> Can you post the full output of v.import with --verbose?
>>> Considering that you override the projection check with -o, you can
>>> also use v.in.ogr directly and then post the full output of v.in.ogr
>>> -o --verbose.
>>> Markus M
>>> > Thanks for your help.
>>> > Camille Bezzina
>>> > Geophom
>>> > _______________________________________________
>>> > grass-user mailing list
>>> > grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
>>> > https://lists.osgeo.org/mailman/listinfo/grass-user
>> Camille BEZZINA
>> Chargé d'études géomatiques et photomontages
>> Geophom
>> 57 rue du Chemin Neuf 44521 OUDON
>> Standard: +33(0)2 85 52 02 59
>> Ligne directe: +33(0)9 72 56 81 71
>> www.geophom.fr
Camille BEZZINA
Geophom
www.geophom.fr
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180418/c7fad1fd/attachment-0001.html>
(Wed Apr 18 17:23:37 2018)
v.import input=/media/hdd1/phom/eolien/AIP_UNESCO_RONCHAMP/data/qgis/MNE/bati_D90_decoupe_test_reduit1.shp layer=bati_D90_decoupe_test_reduit1 output=bati_D90_decoupe_test_reduit1 -o --overwrite
WARNING: Datum <Reseau_Geodesique_Francais_1993> non reconnu par GRASS et aucuns paramètres trouvés
Over-riding projection check
Check if OGR layer <bati_D90_decoupe_test_reduit1> contains polygons...
WARNING: La couche vectorielle <bati_D90_decoupe_test_reduit1> existe déjà et va être écrasé
Importing 50 features (OGR layer <bati_D90_decoupe_test_reduit1>)...
Enregistrement des primitives ...
592 primitives registered
1403 vertices registered
Nombre de nœuds: 559
Nombre de primitives: 592
Nombre de points: 0
Nombre de lignes :0
Nombre de contours: 592
Nombre de centroïdes: 0
Nombre de surfaces: -
Nombre d'îles: -
Cleaning polygons
Snapping boundaries (threshold = 1.000e-13)...
Reading features...
Accrochage des sommets passe 1 : sélection des points
Accrochage des sommets passe 2 : assignation des ancrages de sommets
Accrochage des sommets passe 3 : accrochage sur les points assignés
Breaking polygons...
Breaking polygons (pass 1: select break points)...
Breaking polygons (pass 2: break at selected points)...
Removing duplicates...
Breaking boundaries...
Cleaning boundaries at nodes...
Merging boundaries...
Removing dangles...
Construction des surfaces ...
51 areas built
38 isles built
Nombre de nœuds: 590
Nombre de primitives: 674
Nombre de points: 0
Nombre de lignes :0
Nombre de contours: 674
Nombre de surfaces: 51
Nombre d'îles: 38
WARNING: Nombre de contours incorrects: 22
Removing bridges...
101 primitives registered
911 vertices registered
30 areas built
30 isles built
Attachement des îles ...
Nombre de nœuds: 102
Nombre de primitives: 101
Nombre de points: 0
Nombre de lignes :0
Nombre de contours: 101
Nombre de surfaces: 30
Nombre d'îles: 30
WARNING: Nombre de contours incorrects: 71
Finding centroids for OGR layer <bati_D90_decoupe_test_reduit1>...
Writing centroids...
50 input polygons
Total area: 142222 (30 areas)
Area without category: 26.48 (1 areas)
Copie des objets ...
Construction de la topologie pour la carte vectorielle <bati_D90_decoupe_test_reduit1 at AIP_RONCHAMP_MNE>...
130 primitives registered
940 vertices registered
51 areas built
38 isles built
Attachement des centroïdes ...
Nombre de nœuds: 66
Nombre de primitives: 130
Nombre de points: 0
Nombre de lignes :0
Nombre de centroïdes: 29
Nombre d'îles: 38
21 input polygons got lost during import.
The snapping threshold 1e-13 might be too large.
Manual cleaning may be needed.
Input </media/hdd1/phom/eolien/AIP_UNESCO_RONCHAMP/data/qgis/MNE/bati_D90_decoupe_test_reduit1.shp> successfully imported without reprojection
(Wed Apr 18 17:23:39 2018) La commande s'est terminée (1 sec)
Type: application/pdf
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180418/c7fad1fd/attachment-0001.pdf>
