[GRASS-user] script html manual file directory
Frank David frank.david at geophom.fr
Fri Apr 27 07:08:00 PDT 2018
Thank you Moritz,
I succeed to install python script, But.. my script use a custom lib in
a sub-folder for my shared functions, so g.extension fails with the line
"from gg.geolib import *". How may I manage this included lib ?
Without this include, install works (only on console, not with gui) and
allows to exec the script from console. I notice encoding manual is not
in UTF-8. Is it possible to force UTF-8 encoding ?. However, my custom
menu (toolboxes.xml) fails with the following error :
"/usr/local/grass-7.4.0svn/gui/wxpython/lmgr/frame.py", line
905, in OnMenuCmd
GUI(parent=self, giface=self._giface).ParseCommand(cmd)
   File
"/usr/local/grass-7.4.0svn/gui/wxpython/gui_core/forms.py",
line 2834, in ParseCommand
raise gcmd.GException(e.value)
core.gcmd
GException
Unable to fetch interface description for command
'gzvibin.py'.
Details: [Errno 2] No such file or directory
Thank you for your help.
Frank
Le 26/04/2018 à 14:36, Moritz Lennert a écrit :
> On 26/04/18 12:05, Frank David wrote:
>> Dear all,
>> I would like to setup the manual page of my python scripts in the gui. I
>> alreaday create them from --html-description and put them in my script
>> directory. But it does not work. I tried in ../docs/html/ but without
>> sccess. If I copy them in /usr/local/grass-7.4.0/docs/html it works !
>> Is there any way (html path variable ?) to use html from a personnal
>> directory ?
> You can install your scripts as extension modules. Then the man pages
> will be installed in .grass7/addons/docs.
> The easiest would be to create a directory for each module with the
> code, a ModuleName.html file with the sections DESCRIPTION, NOTES,
> AUTHOR, etc (but not the output of --html-description, this will be
> added automatically !), and a Makefile. You can then call g.extension
> with the url= parameter pointing to that directory and everything will
> be installed automatically. Look at any of the Python modules in
> https://trac.osgeo.org/grass/browser/grass-addons/grass7 to see how to
> write the Makefile and what the content of the .html file looks like.
> Moritz
*Geophom*
327 rue de Vieille Cour 44521 OUDON
Tel +33(0)2 85 52 02 59 - Port +33(0)6 04 47 91 06
www.geophom.fr
-------------- section suivante --------------
Une pièce jointe HTML a été nettoyée...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180427/af821a4c/attachment.html>
