[GRASS-user] conversion to fire simulation data set in the	Grass GIS
    Thomas Adams
    tea3rd at gmail.com
    Sat Aug  4 06:06:36 PDT 2018
Kalindu,
I think you need to provide more information. It sounds like you have point
data, which means your data should be imported using v.in.ogr or
v.in.ascii, if you were to convert you excel file to an ascii text file.
Regards,
Tom
On Sat, Aug 4, 2018 at 3:46 AM, Kalindu Perera <kkc199408 at gmail.com> wrote:
> Hi everyone,
> We have encountered a problem when we trying to convert a wildfire data
> set to the format that can be used in the grass GIS. We have the data in an
> excel sheet as records. Grass GIS fire simulation dataset has a set of
> files as the inputs. The format of the data in the files is unclear. Is
> there any conversion method of normal fire data to the format that can be
> used in the Grass GIS?...We have the same input data, we need to convert
> them like the fire simulation data set provided in the Grass GIS sample
> data page.
> Thank you...!!!!!!!
> Awaiting a helpful response
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180804/0aea355a/attachment.html>
