[GRASS-user] conversion to fire simulation data set in the Grass GIS
Kalindu Perera kkc199408 at gmail.com
Sat Aug 4 07:01:20 PDT 2018
Hi Thomas,
Thanks a lot for your reply. I'll explain more.
We have a dataset with data about a wildfire, starting point of the fire,
slope, wind velocity, wind direction, elevation, fuel models and fuel
moisture.
That data is in an excel sheet separated into columns.
we need to convert that data to the format which is like in the Grass GIS
fire simulation data set. So that we can calculate the spread of our
wildfire using r.ros
Grass GIS fire simulation data set has data about 1 wildfire and the data
is presented separately as files. As an example slope is a separate file.
the elevation is another file
What we need is how to convert our wildfire data which is in the excel
sheet to those type of files?
Is there any script or something to convert?
Thank you..!!!!!!
On Sat, 4 Aug 2018 at 18:36, Thomas Adams <tea3rd at gmail.com> wrote:
> Kalindu,
> I think you need to provide more information. It sounds like you have
> point data, which means your data should be imported using v.in.ogr or
> v.in.ascii, if you were to convert you excel file to an ascii text file.
> Regards,
> Tom
> On Sat, Aug 4, 2018 at 3:46 AM, Kalindu Perera <kkc199408 at gmail.com>
> wrote:
>> Hi everyone,
>> We have encountered a problem when we trying to convert a wildfire data
>> set to the format that can be used in the grass GIS. We have the data in an
>> excel sheet as records. Grass GIS fire simulation dataset has a set of
>> files as the inputs. The format of the data in the files is unclear. Is
>> there any conversion method of normal fire data to the format that can be
>> used in the Grass GIS?...We have the same input data, we need to convert
>> them like the fire simulation data set provided in the Grass GIS sample
>> data page.
>> Thank you...!!!!!!!
>> Awaiting a helpful response
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180804/d733fce6/attachment-0001.html>
