[GRASS-user] conversion to fire simulation data set in the Grass GIS
Kalindu Perera kkc199408 at gmail.com
Sat Aug 4 10:45:10 PDT 2018
Thanks a lot, Rich...!!!!!!! For your valuable information
We also need to convert our one file to that type of dataset.
We are asking for that conversion mechanism.
Regards
On Sat, 4 Aug 2018 at 23:09, Rich Shepard <rshepard at appl-ecosys.com> wrote:
> On Sat, 4 Aug 2018, Kalindu Perera wrote:
> > The inputs to the wildfire model in grass GIS use data as separate files.
> > we need to convert our sheet to that type of set of separate data files.
> Kalindu,
>    In grass, all 'themes,' or 'layers' are kept as separate maps, not a
> single file. For example, your DEM for the area of a wildfire will be in
> one
> raster map, the slope and aspect in another, etc. This way you can combine
> each specific map with others to perform the analyses needed.
>    Keeping everything in a single file, such as your spreadsheet, does not
> support re-use.
>    As you learn more about grass you'll appreciate the differences.
> HTH,
> Rich
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180804/c93ec0da/attachment.html>
