[GRASS-user] conversion to fire simulation data set in the Grass GIS
Helmut Kudrnovsky
hellik at web.de
Sat Aug 4 13:24:40 PDT 2018
>We also need to convert our one file to that type of dataset.
looking at the r.ros manual
(https://grass.osgeo.org/grass75/manuals/r.ros.html)
model=name [required]
Raster map containing fuel models
Name of an existing raster map layer in the user's current mapset search
path containing the standard fuel models defined by the USDA Forest Service.
Valid values are 1-13; other numbers are recognized as barriers by r.ros.
moisture_1h=name
Raster map containing the 1-hour fuel moisture (%)
path containing the 1-hour (<.25") fuel moisture (percentage content
multiplied by 100).
moisture_10h=name
Raster map containing the 10-hour fuel moisture (%)
path containing the 10-hour (.25-1") fuel moisture (percentage content
multiplied by 100).
moisture_100h=name
Raster map containing the 100-hour fuel moisture (%)
path containing the 100-hour (1-3") fuel moisture (percentage content
multiplied by 100).
moisture_live=name [required]
Raster map containing live fuel moisture (%)
path containing live (herbaceous) fuel moisture (percentage content
multiplied by 100).
velocity=name
Raster map containing midflame wind velocities (ft/min)
path containing wind velocities at half of the average flame height
(feet/minute).
direction=name
Name of raster map containing wind directions (degree)
path containing wind direction, clockwise from north (degree).
these are raster maps
looking at the r.ros sample data set
(https://grass.osgeo.org/sampledata/fire_grass6data.tar.gz)
g.list type=raster
1hour_moisture
CVS
aspect
elevation
fire_origin
fuel_model
image_burned
live_moisture
my_path
my_ros.base
my_ros.max
my_ros.maxdir
my_ros.spotdist
slope
spread_time_observed
wind_direction
wind_speed
looking at your excel file, it seems there are only a few points with some
additional information like Latitude, Longitude, Slope, Elevation, Aspect.
these are vector points.
for a simulation in a computional region of your interest, you need these
input raster maps mentioned in the the r.ros, r.spread and r.spreadpath
manuals.
it seems these input raster maps can't be produced by your point information
data; these input raster maps may be compiled by yourself based on some
suppporting data by yourself.
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
