[GRASS-user] db.out.ogr issues
Rich Shepard rshepard at appl-ecosys.com
Fri Aug 10 06:45:39 PDT 2018
On Thu, 9 Aug 2018, Daniel Victoria wrote:
> Try using v.to.db to add the coordinates of each point to the attribute
> table and then export it using DB.out.ogr.
Daniel,
   The points have an elevation -- in feet -- associated with the geographic
location. Is there a grass module that will convert that attribute table
column to meters (the location's lenth units)? Or, should I do this on the
source data and re-import/re-project these data?
Regards,
Rich
