[GRASS-user] db.out.ogr issues
Rich Shepard rshepard at appl-ecosys.com
Fri Aug 10 05:36:33 PDT 2018
On Thu, 9 Aug 2018, Daniel Victoria wrote:
> The lat/long coordinates you get from DB.out.ogr probably comes from your
> vector attributes, which contains the old coordinates.
Daniel,
   Yes, that's the source since db.out.ogr dumps the attribute table.
> When you project the data in Grass, the coordinates in the vector geometry
> are updated but the attribute table is not changed.
   Ah, I didn't consider this. Makes sense
> Try using v.to.db to add the coordinates of each point to the attribute
> table and then export it using DB.out.ogr.
   Sure. I can call the new columns 'east' and 'north'.
Thanks,
Rich
