[GRASS-user] v.to.db fails
Helmut Kudrnovsky hellik at web.de
Sat Aug 11 02:43:57 PDT 2018
>   Creating a new location specifying EPSG:4326 created the location, but
did
>not produce a PROJ_INFO file so I could not reproject the map imported
>there.
not confirmed here; creating a  new location with EPSG:4326 creates
following:
g.proj -p
-PROJ_INFO-------------------------------------------------
datum      : wgs84
ellps      : wgs84
proj       : ll
no_defs    : defined
towgs84    : 0.000,0.000,0.000
-PROJ_EPSG-------------------------------------------------
epsg       : 4326
-PROJ_UNITS------------------------------------------------
unit       : degree
units      : degrees
meters     : 1.0
and produces following file:
D:\grassdata\test_epsg4326\PERMANENT>ls
DEFAULT_WIND  MYNAME  PROJ_EPSG  PROJ_INFO  PROJ_UNITS  WIND
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
