[GRASS-user] Creating presentation maps: g.gui.psmap, ps.map, wx.psmap
Rich Shepard rshepard at appl-ecosys.com
Mon Aug 13 15:58:03 PDT 2018
   The g.gui.psmap manual page's description for the module includes the
statement, "It works better with files created by wx.psmap (more tested)." I
cannot find wx.psmap.
   Backing up to the parent page (the Cartography box in the lower left
corner) and navigating to the postscript commands manual produces the
heading of the parent page:
"GRASS GIS 7.5.svn Reference Manual
Geographic Resources Analysis Support System, commonly referred to as GRASS,
is a Geographic Information System (GIS) used for geospatial data management
and analysis, image processing, graphics/maps production, spatial modeling,
and visualization. GRASS is currently used in academic and commercial
settings around the world, as well as by many governmental agencies and
environmental consulting companies.
This reference manual details the use of modules distributed with Geographic
Resources Analysis Support System (GRASS), an open source (GNU GPLed), image
processing and geographic information system (GIS).
Go back to help overview"
   Tucked away under that is the link,
  "Postscript commands:
ps.map 	Produces hardcopy PostScript map output."
   I suggest that the page be eliminated and the link from the main module
directory's 'Cartography' link go directly to
<https://grass.osgeo.org/grass75/manuals/ps.map.html>.
   At the bottom of the psmap page is a section, "CHANGES BETWEEN VERSION 5.0.x/5.4.x and
6.0" that probably be safely removed.
   It has been many years since I've used ps.map. If I'm correctly reading
the manual for g.gui.psmap I need to create the ps.map input *.txt file,
then use g.gui.psmap to tweak it. Is this correct?
Regards,
Rich
