[GRASS-user] New CLI option --tmp-location in 7.5 to enhance --exec
Stefan Blumentrath
Stefan.Blumentrath at nina.no
Thu Aug 16 01:37:39 PDT 2018
Dear Pierre,
Just in case you are not aware of it, GRASS and R integrate very nicely:
https://grasswiki.osgeo.org/wiki/R_statistics/rgrass7
Cheers,
Stefan
-----Original Message-----
From: grass-user <grass-user-bounces at lists.osgeo.org> On Behalf Of Pierre Roudier
Sent: torsdag 16. august 2018 10:07
To: Vaclav Petras <wenzeslaus at gmail.com>
Cc: GRASS user list <grass-user at lists.osgeo.org>
Subject: Re: [GRASS-user] New CLI option --tmp-location in 7.5 to enhance --exec
Thanks Vaclav,
Looks like a great enhancement. It should make it easy to wrap it into a R package for example.
One question -- is that possible to refer to the input dataset in the script called by --exec? Something like:
grass --tmp-location ~/data/elevation.tiff --exec "r.param.scale in=myinput out=myoutput param=slope size=9"
Cheers,
P
On 15 August 2018 at 15:20, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> Dear user list,
> The (main) GRASS GIS executable, usually available as simply `grass`
> on most systems has now a new option (flag/parameter) in trunk (aka
> 7.5). The option is called --tmp-location.
> When specified, GRASS GIS automatically creates an new (and empty)
> location based on provided EPSG code or georeferenced file (similarly
> to what -c flag does). Newly it is also possible to provide string
> "XY" instead of EPSG to create XY (non-georeferenced) location.
> This temporary location has only PERMANENT mapset and the whole
> location is removed. The location is created in a temporary directory
> (which is also deleted at the end).
> The flag --tmp-location is meant to be used together with --exec and
> it is a part of a lager endeavor to make the CLI easier for use from
> outside of the GRASS GIS session.
> If you are interested, please, test this new functionality. It is an
> opportunity to provide feedback before this feature lands in the 7.6
> release.
> Here are some things to try:
> * Execute a module in a location created based on EPSG:
> grass --tmp-location EPSG:3358 --exec g.region -p
> * Execute Python script in a location created based on EPSG:
> grass --tmp-location EPSG:3358 --exec script.py
> * Examine the created location using a Bash command:
> grass --tmp-location EPSG:3358 --exec bash -c "g.proj -p && g.region
> -p && g.mapset -p && g.gisenv GISDBASE,LOCATION_NAME sep=/"
> * Get SRS/CRS for a file:
> grass --tmp-location ~/data/elevation.tiff --exec g.proj -p
> * Get help text for a module:
> grass --tmp-location XY --exec r.neighbors --help
> See the documentation and `grass --help` for more hints (and let me
> know how these can be enhanced).
> Best regards,
> Vaclav
> https://trac.osgeo.org/grass/ticket/3537
> https://trac.osgeo.org/grass/ticket/3585
> https://trac.osgeo.org/grass/ticket/3586
> https://trac.osgeo.org/grass/changeset/72790
> https://trac.osgeo.org/grass/changeset/73096
> https://trac.osgeo.org/grass/changeset/73098
> https://trac.osgeo.org/grass/changeset/73099
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
