[GRASS-user] New CLI option --tmp-location in 7.5 to enhance --exec
Pierre Roudier
pierre.roudier at gmail.com
Thu Aug 16 01:42:48 PDT 2018
Thanks Stephan,
I'm aware of rgrass7 and spgrass6 -- I had in mind a package a lot
lighter, that basically "hides" the specificities of GRASS (eg the
notions of GRASSDATA, of locations, of mapsets...) from the user, and
just run a GRASS command on a GDAL/OGR type file.
Cheers,
P
On 16 August 2018 at 20:37, Stefan Blumentrath
<Stefan.Blumentrath at nina.no> wrote:
> Dear Pierre,
> Just in case you are not aware of it, GRASS and R integrate very nicely:
> https://grasswiki.osgeo.org/wiki/R_statistics/rgrass7
> Cheers,
> Stefan
> -----Original Message-----
> From: grass-user <grass-user-bounces at lists.osgeo.org> On Behalf Of Pierre Roudier
> Sent: torsdag 16. august 2018 10:07
> To: Vaclav Petras <wenzeslaus at gmail.com>
> Cc: GRASS user list <grass-user at lists.osgeo.org>
> Subject: Re: [GRASS-user] New CLI option --tmp-location in 7.5 to enhance --exec
> Thanks Vaclav,
> Looks like a great enhancement. It should make it easy to wrap it into a R package for example.
> One question -- is that possible to refer to the input dataset in the script called by --exec? Something like:
> grass --tmp-location ~/data/elevation.tiff --exec "r.param.scale in=myinput out=myoutput param=slope size=9"
> Cheers,
> P
> On 15 August 2018 at 15:20, Vaclav Petras <wenzeslaus at gmail.com> wrote:
>> Dear user list,
>> The (main) GRASS GIS executable, usually available as simply `grass`
>> on most systems has now a new option (flag/parameter) in trunk (aka
>> 7.5). The option is called --tmp-location.
>> When specified, GRASS GIS automatically creates an new (and empty)
>> location based on provided EPSG code or georeferenced file (similarly
>> to what -c flag does). Newly it is also possible to provide string
>> "XY" instead of EPSG to create XY (non-georeferenced) location.
>> This temporary location has only PERMANENT mapset and the whole
>> location is removed. The location is created in a temporary directory
>> (which is also deleted at the end).
>> The flag --tmp-location is meant to be used together with --exec and
>> it is a part of a lager endeavor to make the CLI easier for use from
>> outside of the GRASS GIS session.
>> If you are interested, please, test this new functionality. It is an
>> opportunity to provide feedback before this feature lands in the 7.6
>> release.
>> Here are some things to try:
>> * Execute a module in a location created based on EPSG:
>> grass --tmp-location EPSG:3358 --exec g.region -p
>> * Execute Python script in a location created based on EPSG:
>> grass --tmp-location EPSG:3358 --exec script.py
>> * Examine the created location using a Bash command:
>> grass --tmp-location EPSG:3358 --exec bash -c "g.proj -p && g.region
>> -p && g.mapset -p && g.gisenv GISDBASE,LOCATION_NAME sep=/"
>> * Get SRS/CRS for a file:
>> grass --tmp-location ~/data/elevation.tiff --exec g.proj -p
>> * Get help text for a module:
>> grass --tmp-location XY --exec r.neighbors --help
>> See the documentation and `grass --help` for more hints (and let me
>> know how these can be enhanced).
>> Best regards,
>> Vaclav
>> https://trac.osgeo.org/grass/ticket/3537
>> https://trac.osgeo.org/grass/ticket/3585
>> https://trac.osgeo.org/grass/ticket/3586
>> https://trac.osgeo.org/grass/changeset/72790
>> https://trac.osgeo.org/grass/changeset/73096
>> https://trac.osgeo.org/grass/changeset/73098
>> https://trac.osgeo.org/grass/changeset/73099
>> grass-user mailing list
>> https://lists.osgeo.org/mailman/listinfo/grass-user
