[GRASS-user] workflow to import/georectify binary remote sensing data
Markus Neteler neteler at osgeo.org
Thu Aug 16 08:17:38 PDT 2018
Hi Peter,
On Wed, Aug 1, 2018 at 10:29 AM "Peter Löwe" <peter.loewe at gmx.de> wrote:
> Hello list,
> here is a question about what's currently the most effective way to ingest binary raster data which need to be georectified.
> The data source are calibrated weather radar precipitation rasters (lots of them), which come in a well documented binary format (+ GCPs), which is not (yet) supported by gdal.
> A "classical" approach could be:
> 1) Create XY location as source
> 2) Create LatLon location as target
(probably a metric projection would be better?)
> 3) Ingest data via r.in.bin (to skip over file header) into XY location
> 4) Use GCP to set up i.rectify within XY location
> 5) Apply i.rectify
> 6) Discard XY-location and continue work in LatLon location
> In there a more effective way, probably without using a XY location ?
Perhaps the new:
grass75 --tmp-location ...
See
https://grass.osgeo.org/grass75/manuals/grass7.html#batch-jobs-with-the-exec-interface
--> Using temporary location
It also supports XY locations and all could be done in a script.
Best
Markus
