[GRASS-user] ps.map/g.gui.psmap: comments and a request
Rich Shepard
rshepard at appl-ecosys.com
Fri Aug 17 14:16:08 PDT 2018
On Fri, 17 Aug 2018, Rich Shepard wrote:
> One request for enhancing g.gui.psmap when someone has the time and
> inclination to do so.
> When ctrl-shift-e is pressed to export the script as a text file it would
> be great if the behavior was that of 'save file' commands. That is, the
> currently open filename is remembered and overwritten with the current file
> contents, automagically and without human intervention. Now, I need to
> explicitly select the filename and explicitly tell grass to overwrite it.
Oops! I forgot the related second request: when ^F is pressed to export
the map as a .pdf file that, too, should remember the filename and
automagically overwrite it rather than asking the user to re-select the file
and re-confirm the overwriting.
Regards,
Rich
