[GRASS-user] i.atcorr for 30 bands data
Markus Neteler neteler at osgeo.org
Mon Aug 20 08:00:02 PDT 2018
On Thu, Aug 16, 2018 at 6:57 PM kameswari devi <kams.devi at gmail.com> wrote:
> Thank you for the reply.Actually i tried to compile grass 7.4.0 but failed due to missing libraries which have to be downloaded online.As my working machine is offline, i could not get those libraries.I have customized for Hyperion by changing iwave.cpp file and incorporated interpolated rsr of Hyperion.i found that there is no limitation for number of bands.Atmospheric correction is working now for Hyperion.
Suggestion:
If you have the needed code changes, consider to submit an enhancement ticket at
https://trac.osgeo.org/grass/
We can then patch GRASS GIS 7.5 with it and it will go overnight into
the auto-compiled Windows version (from you other email I saw that you
are on Windows).
Then you don't need to create all the compile environment yourself.
Markus
