[GRASS-user] i.atcorr for 30 bands data
    kameswari devi
    kams.devi at gmail.com
    Tue Aug 21 22:54:13 PDT 2018
Thanks, I'll check it out.
On Mon, Aug 20, 2018 at 8:30 PM Markus Neteler <neteler at osgeo.org> wrote:
> On Thu, Aug 16, 2018 at 6:57 PM kameswari devi <kams.devi at gmail.com> wrote:
> > Thank you for the reply.Actually i tried to compile grass 7.4.0 but failed due to missing libraries which have to be downloaded online.As my working machine is offline, i could not get those libraries.I have customized for Hyperion by changing iwave.cpp file and incorporated interpolated rsr of Hyperion.i found that there is no limitation for number of bands.Atmospheric correction is working now for Hyperion.
> Suggestion:
> If you have the needed code changes, consider to submit an enhancement ticket at
> https://trac.osgeo.org/grass/
> We can then patch GRASS GIS 7.5 with it and it will go overnight into
> the auto-compiled Windows version (from you other email I saw that you
> are on Windows).
> Then you don't need to create all the compile environment yourself.
> Markus
Regards
kameswari devi P
