[GRASS-user] v.report output interpretation
Helmut Kudrnovsky hellik at web.de
Tue Aug 21 08:28:47 PDT 2018
Rich Shepard wrote
> On Mon, 20 Aug 2018, Helmut Kudrnovsky wrote:
>> loading the text snippet above into a spreadsheet, columns matches here.
> Helmut,
>    I'm sure it does the same here, but that was not my question. I didn't
> ask
> it properly so I'll try again.
>    The v.report manual page explains that specifying an option of area,
> length, or coordinates is required. The implication is that the user
> selects
> one option which is output in the desired units. The results I obtained
> include everything, despite my asking for only one. If that's the default
> behavior why require declaration of _an_ option?
>    As a side issue, if everything is going to be dumped to the console why
> not eliminate the option option and format output as a two row table
> rather
> than requiring the output to be transferred to a spreadsheet?
Not sure I understand it right, are you refering to
[....]Shape_Length|Shape_Area|area
only the area columns comes from v.report
the other columns are already in the original data.
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
