[GRASS-user] v.vol.rst - not enough disk space to write temp file
Francois Chartier fra.chartier at gmail.com
Wed Dec 19 17:41:41 PST 2018
trying to run v.vol.rst with a larger dataset but using a smaller footprint
for the interpolation, using the same domain than  my previous dataset.
The interpolation does not reach the end of the simulation as there is not
enough disk space.  Any way around this?
(Wed Dec 19 20:24:48 2018)
v.vol.rst --overwrite input=GeomodDec16 at Toronto wcolumn=dbl_2 tension=100
elevation=trialdec16
280957 records selected from table
WARNING: Some points outside of region -- will ignore...
WARNING: Strip exists with insufficient data
Processing all selected output files will require 1830391004 bytes of disk
space for temp files
WARNING: There are points outside specified 2D/3D region--ignored 222354
points (total points: 280957)
WARNING: Points are more dense than specified 'DMIN'--ignored 1946 points
(remain 279011)
WARNING: Unable to create <(null)> raster map without cross_input raster
map being specified
ERROR: Not enough disk space - cannot write temp files
(Wed Dec 19 20:29:56 2018) Command finished (5 min 8 sec)
g.region -3p  [i have set a number of rows and columns to 100 for each, and
res3.value as 1 (not sure if this contradict the number of column and rows)
projection: 1 (UTM)
zone:       17
datum:      nad83
ellipsoid:  grs80
north:      4862000
south:      4846000
west:       609200
east:       651700
top:        250.00000000
bottom:     50.00000000
nsres:      160
nsres3:     0.11358232
ewres:      425
ewres3:     0.44870509
tbres:      2
rows:       100
rows3:      140867
cols:       100
cols3:      94717
depths:     100
cells:      10000
cells3:     1334249963900
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20181219/fb41c0b0/attachment.html>
