[GRASS-user] d.mon displays box on startup
Veronica Andreo
veroandreo at gmail.com
Thu Dec 27 16:24:42 PST 2018
Hi all,
+1 for showing computational region by default! It is a super handy feature
Regarding the different colors, I do not have a very strong opinion. I was
already used to blue for full region extent coincident with display and red
when display is different from region extent.
Case 3b proposed, IIUC, would mean that display will have incomplete lines
and that seems more confusing in my view. I would suggest that (if
implemented like this) 3b is shown as 3a.
my2cents
Vero
El lun., 24 dic. 2018 a las 15:30, Huidae Cho (<grass4u at gmail.com>)
escribió:
> Maybe, this figure is easier to understand. blue for comp region and red
> for partial version.
> Black: display
> Blue: full comp region
> Red: partial intersection of display and full comp region
> In this color scheme, it's very clear what we're looking at in the display.
> [image: image.png]
> Huidae
> On Mon, Dec 24, 2018 at 9:06 AM Huidae Cho <grass4u at gmail.com> wrote:
>> So how does it work now in one color?
>> 1. display == full comp region: red box
>> 2. display > and contains full comp region: red box smaller than display
>> 3. display < and inside full comp region: no box at all? (can be
>> confusing with cases 4 & 5) or red box (can be confusing with case 1). I
>> think we need two colors in this case? Actual comp region borders red,
>> Display borders within comp region blue (maybe, switching blue and red
>> would be better?). For example, completely inside (not crossing any comp
>> region boundaries) blue box. Looking at the east comp region boundary:
>> vertical line in red, top-left, bottom-left, and left in blue. Again, I
>> think if we use red and blue, it would be better to use blue for comp
>> region borders and red for partially/contained borders.
>> 4. display > and does not contain full comp region: no box
>> 5. display < and outside full comp region: no box
>> Huidae
>> On Mon, Dec 24, 2018 at 7:02 AM Martin Landa <landa.martin at gmail.com>
>> wrote:
>>> Hi,
>>> st 26. 9. 2018 v 20:27 odesílatel Anna Petrášová <kratochanna at gmail.com>
>>> napsal:
>>> > I think it changes color depending if you are zoomed inside or outside
>>> of the region. I find this behavior little bit confusing, perhaps just
>>> having one color would be enough, and maybe don't show it when you are
>>> zoomed inside?
>>> in r73826 the settings was changed to show comp. region extent in red
>>> color only regardless display and computation extent position. If no
>>> objection I will do backport to g76 release branch in next days.
>>> Question is whether comp. region extent should be displayed by
>>> default. The behaviour has been changed accordingly [1], but
>>> unfortunately there was no feedback. Any opinion (since it affects
>>> 7.6.0 release)?
>>> Ma
>>> [1] https://trac.osgeo.org/grass/ticket/3519
>>> Martin Landa
>>> http://geo.fsv.cvut.cz/gwiki/Landa
>>> http://gismentors.cz/mentors/landa
>> Huidae Cho, Ph.D., GISP, PE (MD), CFM, M.ASCE
>> Open Source GIS Developer, GRASS GIS Development Team
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20181228/365777a0/attachment.html>
