[GRASS-user] d.mon displays box on startup
Huidae Cho
grass4u at gmail.com
Thu Dec 27 17:16:53 PST 2018
Hello Vero,
Actually, 3b has a complete rectangle (NW in red, SE in blue).
Regards,
Huidae
On Thu, Dec 27, 2018 at 7:24 PM Veronica Andreo <veroandreo at gmail.com>
wrote:
> Hi all,
> +1 for showing computational region by default! It is a super handy
> feature :)
> Regarding the different colors, I do not have a very strong opinion. I was
> already used to blue for full region extent coincident with display and red
> when display is different from region extent.
> Case 3b proposed, IIUC, would mean that display will have incomplete lines
> and that seems more confusing in my view. I would suggest that (if
> implemented like this) 3b is shown as 3a.
> my2cents
> Vero
> El lun., 24 dic. 2018 a las 15:30, Huidae Cho (<grass4u at gmail.com>)
> escribió:
>> Maybe, this figure is easier to understand. blue for comp region and red
>> for partial version.
>> Black: display
>> Blue: full comp region
>> Red: partial intersection of display and full comp region
>> In this color scheme, it's very clear what we're looking at in the
>> display.
>> [image: image.png]
>> Huidae
>> On Mon, Dec 24, 2018 at 9:06 AM Huidae Cho <grass4u at gmail.com> wrote:
>>> So how does it work now in one color?
>>> 1. display == full comp region: red box
>>> 2. display > and contains full comp region: red box smaller than display
>>> 3. display < and inside full comp region: no box at all? (can be
>>> confusing with cases 4 & 5) or red box (can be confusing with case 1). I
>>> think we need two colors in this case? Actual comp region borders red,
>>> Display borders within comp region blue (maybe, switching blue and red
>>> would be better?). For example, completely inside (not crossing any comp
>>> region boundaries) blue box. Looking at the east comp region boundary:
>>> vertical line in red, top-left, bottom-left, and left in blue. Again, I
>>> think if we use red and blue, it would be better to use blue for comp
>>> region borders and red for partially/contained borders.
>>> 4. display > and does not contain full comp region: no box
>>> 5. display < and outside full comp region: no box
>>> Huidae
>>> On Mon, Dec 24, 2018 at 7:02 AM Martin Landa <landa.martin at gmail.com>
>>> wrote:
>>>> Hi,
>>>> st 26. 9. 2018 v 20:27 odesílatel Anna Petrášová <kratochanna at gmail.com>
>>>> napsal:
>>>> > I think it changes color depending if you are zoomed inside or
>>>> outside of the region. I find this behavior little bit confusing, perhaps
>>>> just having one color would be enough, and maybe don't show it when you are
>>>> zoomed inside?
>>>> in r73826 the settings was changed to show comp. region extent in red
>>>> color only regardless display and computation extent position. If no
>>>> objection I will do backport to g76 release branch in next days.
>>>> Question is whether comp. region extent should be displayed by
>>>> default. The behaviour has been changed accordingly [1], but
>>>> unfortunately there was no feedback. Any opinion (since it affects
>>>> 7.6.0 release)?
>>>> Ma
>>>> [1] https://trac.osgeo.org/grass/ticket/3519
>>>> Martin Landa
>>>> http://geo.fsv.cvut.cz/gwiki/Landa
>>>> http://gismentors.cz/mentors/landa
>>> Huidae Cho, Ph.D., GISP, PE (MD), CFM, M.ASCE
>>> Open Source GIS Developer, GRASS GIS Development Team
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20181227/a955b1c1/attachment.html>
