[GRASS-user] d.mon displays box on startup
Veronica Andreo veroandreo at gmail.com
Thu Dec 27 18:22:24 PST 2018
Hi Huidae,
El jue., 27 dic. 2018 22:17, Huidae Cho <grass4u at gmail.com> escribió:
> Hello Vero,
> Actually, 3b has a complete rectangle (NW in red, SE in blue)
Right :)
I overlooked the blue part. Still, IMHO, case 3b it's confusing.
Best,
Vero
On Thu, Dec 27, 2018 at 7:24 PM Veronica Andreo <veroandreo at gmail.com>
> wrote:
>> Hi all,
>> +1 for showing computational region by default! It is a super handy
>> feature :)
>> Regarding the different colors, I do not have a very strong opinion. I
>> was already used to blue for full region extent coincident with display and
>> red when display is different from region extent.
>> Case 3b proposed, IIUC, would mean that display will have incomplete
>> lines and that seems more confusing in my view. I would suggest that (if
>> implemented like this) 3b is shown as 3a.
>> my2cents
>> Vero
>> El lun., 24 dic. 2018 a las 15:30, Huidae Cho (<grass4u at gmail.com>)
>> escribió:
>>> Maybe, this figure is easier to understand. blue for comp region and red
>>> for partial version.
>>> Black: display
>>> Blue: full comp region
>>> Red: partial intersection of display and full comp region
>>> In this color scheme, it's very clear what we're looking at in the
>>> display.
>>> [image: image.png]
>>> Huidae
>>> On Mon, Dec 24, 2018 at 9:06 AM Huidae Cho <grass4u at gmail.com> wrote:
>>>> So how does it work now in one color?
>>>> 1. display == full comp region: red box
>>>> 2. display > and contains full comp region: red box smaller than display
>>>> 3. display < and inside full comp region: no box at all? (can be
>>>> confusing with cases 4 & 5) or red box (can be confusing with case 1). I
>>>> think we need two colors in this case? Actual comp region borders red,
>>>> Display borders within comp region blue (maybe, switching blue and red
>>>> would be better?). For example, completely inside (not crossing any comp
>>>> region boundaries) blue box. Looking at the east comp region boundary:
>>>> vertical line in red, top-left, bottom-left, and left in blue. Again, I
>>>> think if we use red and blue, it would be better to use blue for comp
>>>> region borders and red for partially/contained borders.
>>>> 4. display > and does not contain full comp region: no box
>>>> 5. display < and outside full comp region: no box
>>>> Huidae
>>>> On Mon, Dec 24, 2018 at 7:02 AM Martin Landa <landa.martin at gmail.com>
>>>> wrote:
>>>>> Hi,
>>>>> st 26. 9. 2018 v 20:27 odesílatel Anna Petrášová <
>>>>> kratochanna at gmail.com> napsal:
>>>>> > I think it changes color depending if you are zoomed inside or
>>>>> outside of the region. I find this behavior little bit confusing, perhaps
>>>>> just having one color would be enough, and maybe don't show it when you are
>>>>> zoomed inside?
>>>>> in r73826 the settings was changed to show comp. region extent in red
>>>>> color only regardless display and computation extent position. If no
>>>>> objection I will do backport to g76 release branch in next days.
>>>>> Question is whether comp. region extent should be displayed by
>>>>> default. The behaviour has been changed accordingly [1], but
>>>>> unfortunately there was no feedback. Any opinion (since it affects
>>>>> 7.6.0 release)?
>>>>> Ma
>>>>> [1] https://trac.osgeo.org/grass/ticket/3519
>>>>> Martin Landa
>>>>> http://geo.fsv.cvut.cz/gwiki/Landa
>>>>> http://gismentors.cz/mentors/landa
>>>> Huidae Cho, Ph.D., GISP, PE (MD), CFM, M.ASCE
>>>> Open Source GIS Developer, GRASS GIS Development Team
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20181227/0ec99f7a/attachment-0001.html>
